temp gauge issues at full throttle....why??
Old Nov 14, 2007 | 09:13 PM
floatfisher's Avatar
Default temp gauge issues at full throttle....why??
well in the summer i changed my thermostat with an oem one. Worked mostly fine all summer. Had no issues at the track. Now that its much cooler outside, sometimes at full throttle my temp gauge drops a tiny bit. Especially if i turn the heat on.
Ive read old threads about thermostats but i havent got anything from them. Is there something else i should look for??
thanks
Old Nov 14, 2007 | 09:29 PM
JjuuN R's Avatar
Default Re: temp gauge issues at full throttle....why?? (floatfisher)
It's normal... doesn't happen with me, but it's all common sense.
Old Nov 14, 2007 | 10:07 PM
itralex's Avatar
Default Re: temp gauge issues at full throttle....why?? (JjuuN R)
Its normal, more faster air moving through the radiator = cooler car
try running a bigger radiator, the temp gauge drops down to full cold during the winter when you're on full throttle
Old Nov 15, 2007 | 11:52 AM
if its normal how come it never did this when i first bought the car?? when the heats on the temp drops down 1 full line on the gauge...this cant be good for my motor
Old Nov 15, 2007 | 12:26 PM
JjuuN R's Avatar
Default Re: (floatfisher)
Because you changed the thermostat, maybe it just reads a little differently for some reason, and your temp dropping 1 bar isn't going to harm your motor man...
Old Nov 15, 2007 | 12:36 PM
andyt's Avatar
Make sure you don't have an electrical problem.
Maybe at full throttle the engine moves enough to pull on the wires and cause the gauge to fluctuate.
I've had that same issue on my car.
Old Nov 15, 2007 | 12:58 PM
JjuuN R's Avatar
Default Re: (andyt)
It's funny how a bad motor mount or two could be the culprit of this.
Old Nov 15, 2007 | 11:37 PM
ill check for this tomorrow although i think the mounts are fine
Old Nov 19, 2007 | 09:46 AM
frozenb's Avatar
same problem here, fine in summer and now.
if i am on hwy, temperature drop to like around full cold(C). this is after i replace my rad(not aluminum one). final check is the thermostat problem
djfob
Feb 16, 2018 05:27 PM
Geauxkart
Nov 23, 2005 11:30 AM
B00STED Si
Jun 16, 2005 08:26 AM
ButterMule
Nov 27, 2004 10:19 AM
Quik89Si
23
Jan 11, 2003 11:03 AM
