Starting Problems I'm stumped
Old Nov 14, 2007 | 04:11 PM
iv's Avatar
iv
Default Starting Problems I'm stumped
This has got me stumped
I just put a swap in to a EG the swap worked perfect when I took it out it sat for 9 months the only thing I changed before installing it was the injectors the car I put it into had a b-series in it before I bought it
The car will not start it has spark it has fuel
I have tried two different ECU's and I have tried 2 sets of injectors
The weird thing is if you spray carb cleaner in the throttle body it will fire and start until the carb cleaner is gone but I know for a fact is is getting fuel but it will not start
I checked all the injector wiring it is good and I checked the PGMFI relay it is plugged in
Anybody got any ideas
Old Nov 14, 2007 | 06:39 PM
iv's Avatar
iv
Default Re: Starting Problems I'm stumped (iv)
tt
Old Nov 14, 2007 | 06:40 PM
EGmikeH22's Avatar
* B A N N E D *
sounds like your plug wires are plugged in the wrong order.
1342
Old Nov 14, 2007 | 06:48 PM
iv's Avatar
iv
No I checked that I didnt touch the plug wires from the other car to this car
While reading the search results I see that most people think that it is the distributer but it worked fine when I took it out could it go bad just sitting there??
Old Nov 14, 2007 | 06:55 PM
spray_bombed's Avatar
Default Re: (iv)
sitting than long you might have gotten moisture inside the cap....check that
Old Nov 16, 2007 | 06:29 AM
iv's Avatar
iv
Dizzy seems to be fine I have spark on all 4 plugs
Old Nov 16, 2007 | 08:48 AM
maybe the injectors are leaking and dumped fuel into the motor while it was sitting and flooded the engine?....i dont really know what to tell you
coomplife05
May 28, 2014 09:01 PM
mike11
Jul 30, 2012 08:26 PM
rudeboy
May 7, 2008 05:32 AM
pdiggitydogg
62
Nov 10, 2007 01:28 PM
db8sedan
Aug 29, 2005 09:14 AM
