car doesnt start......
Old Nov 14, 2007 | 03:34 PM
aztigen_eh2's Avatar
Default car doesnt start......
i just use my car then parked it with no problem.. then 2 hrs later when i start it..
it cranks but ddnt start.. the CEL wont turn off..
coz i usually hear some noise then a click b4 the CEL turn off..
and i dont hear a click b4 i start it....
some told me its the fuel pump? but i dnt knw..
help me pls
Old Nov 14, 2007 | 03:47 PM
jdm_eg's Avatar
Starter relay but thats just my guess
Old Nov 14, 2007 | 04:03 PM
thanks?
anymore opnions?
Old Nov 14, 2007 | 06:07 PM
hoo my gosh's Avatar
i hate to be one of those guys but i see one or two of these threads everyday
» Search Results
Your search for car start returned 115 results
Old Nov 14, 2007 | 08:15 PM
Default Re: (hoo my gosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoo my gosh &raquo;</TD></TR><TR><TD CLASS="quote">i hate to be one of those guys but i see one or two of these threads everyday
» Search Results
Your search for car start returned 115 results</TD></TR></TABLE>
thats what im doing.. im reading the results while waiting 4 some answers on my post.. thanks 4 info..
Old Nov 14, 2007 | 08:24 PM
apc123eg's Avatar
Default Re: (aztigen_eh2)
same thing happent to me took it to the shop and they told me the coil in the distributor went out ...$400 later everything all good .. chick 4 spark
thing you need 4 car to run
fuel
igniton
compression
good luck
Old Nov 14, 2007 | 08:29 PM
PinoyDelSol's Avatar
* B A N N E D *
Default Re: (apc123eg)
If your car is standard, get a friend to help you push you car and just pop start it if you need to bring it in for service.. Other than that, check your starter, Dizzy, sparks plug & wires, etc.. Good luck
Old Nov 14, 2007 | 08:42 PM
Default Re: (PinoyDelSol)
it happened b4 that my car ddnt start, but unlike b4 its all about dizzy theres no CEL.. this time theres CEL and i dont hear any noise or click..
thanks again..
Old Nov 14, 2007 | 09:06 PM
* B A N N E D *
Good Luck with you car though!
Old Nov 14, 2007 | 09:10 PM
92BLKINTEGRA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aztigen_eh2 &raquo;</TD></TR><TR><TD CLASS="quote">it happened b4 that my car ddnt start, but unlike b4 its all about dizzy theres no CEL.. this time theres CEL and i dont hear any noise or click..
thanks again..</TD></TR></TABLE>
No click means main fuel relay is not working.. there should be a click when you first turn the key then another after the CEL light turns off, if there isn't than it's dead. Fairly cheap and very easy fix.
Old Nov 14, 2007 | 10:20 PM
wow... seems i got an answer.. where is that fuel relay thingy located at? thanks
Old Nov 15, 2007 | 02:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aztigen_eh2 &raquo;</TD></TR><TR><TD CLASS="quote">where is that fuel relay thingy located at? thanks</TD></TR></TABLE>
Old Nov 15, 2007 | 08:17 PM
* B A N N E D *
i think its located near the front passenger side right next to the battery when you pop your hood open.. correct me if im wrong.. but i should be right.
Old Nov 15, 2007 | 10:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinoyDelSol &raquo;</TD></TR><TR><TD CLASS="quote">i think its located near the front passenger side right next to the battery when you pop your hood open.. correct me if im wrong.. but i should be right. </TD></TR></TABLE>
i think u talkin bout the fuse boxes?
theres like 3 relays over there like heater motor relay, etc but doesnt say fuel relay? as ive search on yahoo i think its the same as main relay assmbly??
can somebody tell me bout this?n thanks...
Old Nov 17, 2007 | 10:24 AM
i just bought a walbro 255 high pressure yesterday n i put it on
i thought its gonna work ... but my car still wont run!!!!!
Old Nov 17, 2007 | 12:10 PM
EG8R's Avatar
I think you guys meant the main relay. Its located under the dash on the drivers side...
Old Nov 18, 2007 | 02:30 PM
thats ut im thinkin 2.. if its the main relay, then its not the problem coz its workin on other car..
Old Nov 18, 2007 | 09:22 PM
Default Re: (92BLKINTEGRA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92BLKINTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">
No click means main fuel relay is not working.. there should be a click when you first turn the key then another after the CEL light turns off, if there isn't than it's dead. Fairly cheap and very easy fix. </TD></TR></TABLE>
no click, no spark.. do u knw the part number? thanks
Old Nov 18, 2007 | 09:31 PM
dookiemonster's Avatar
Default Re: car doesnt start...... (aztigen_eh2)
starter?
Old Nov 19, 2007 | 04:39 PM
my car's not been runnin 4 a week now
Modified by aztigen_eh2 at 6:12 PM 11/19/2007
Old Nov 20, 2007 | 02:06 PM
help
Old Nov 23, 2007 | 08:03 PM
Old Nov 26, 2007 | 12:51 PM
car runs now.. but dies when ill let go of gas..
Old Nov 26, 2007 | 08:44 PM
i checked the code.. its code 20.. but its still hard 4 me 2 figure it out..
mister.wong
Sep 13, 2008 04:45 PM
johnqt3
Oct 16, 2005 03:16 PM
slipperyduck
Dec 22, 2004 10:40 AM
RiCE On IcE 2
Nov 30, 2004 12:42 PM
Quade
Oct 21, 2004 07:55 AM
