Valve springs ?
i have to take out my valve springs to fix a ticking noise in my valvetrain. Can i put in skunk2 tuner series valve springs and titanium retainers with stock cams becuase oem replacement springs will be the same price if not more so i might as well get better srpings no ? and can you replace the springs with out taking off the head ?
so i can just put in skunk2 tuner springs on stock cams without worring of damagind my cams. Is it worth replacing all my springs with skunk2 springs or just to replace the one broken spring
are you saying should you replace the broken springs with skunk2 springs. so in turn having a mix of oem springs a s2 springs. if so not a good idea. you want either all oem or all skunk2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kadidle »</TD></TR><TR><TD CLASS="quote">so i can just put in skunk2 tuner springs on stock cams without worring of damagind my cams. Is it worth replacing all my springs with skunk2 springs or just to replace the one broken spring</TD></TR></TABLE>
Skunk2 springs will work fine with stock cams.
Broken springs can definitely happen guys, but I honestly doubt this guy has one. If you do have one, whichever way you choose to fix it, make all of the springs uniform, don't use mix matched crap.
Cimburke23
Dec 23, 2010 11:33 AM
