F22A1 POWER OPTIONS
WHAT IS THE EASIEST WAY TO GET POWER OUT OF THE SOHC F22?
I DONT WANT TO DO A MOTOR SWAP....MAYEB EXHAUST -INTAKE
WHAT ELSE IS A GOOD WAY TO GET DECENT POWER
AND WHAT IS THE CHEAPEST MOTOR SWAP?
BEST BANG FOR THE BUCK?
JUST LOOKINF FOR SOMETHING A LITLE QUICKER....
H23-F23 OR A V6???? WHAT CAN BE DONE?
and whats the "decent" power you're looking for and for how much.
and are you serious?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abrown89 »</TD></TR><TR><TD CLASS="quote">WHAT IS THE EASIEST WAY TO GET POWER OUT OF THE SOHC F22?
H23-F23 OR A V6???? WHAT CAN BE DONE?</TD></TR></TABLE>
do you want to do a one or not
find a really big hill and let it roll down....cheap, fun, fast
make your car sound cool...cheap maybe gain 7 hp not a bad way t oget started
turboing it...I highly reccomend that you become familiar with your car and get a grasp on some simple concepts of your car....
depends on your means motovie and motivation...I found a complet H22 swap for 700 bucks...I sold mine for 1300
Nitrous
read before you determine what is "fast" welcome to honda tech dont type in all caps
Nitrous
well it really depends on whether you are looking for out of the deal, and how much time and/or money you want to invest.
rule of thumb says that turbo is going to be hard(er) on an engine, esp if your f22 has higher mileage. you may turbo it and have the motor blow in a short amount of time. if you choose to go turbo, you should have the engine fitted with some new bearings while your at it.
an h22 swap will get you more power than you have now, and are usually more dependable (than boosting a ragged out f22). but then you will have to go through with the swap, which can be a hassle if you are not mechanically inclined. you can always pay to have it done, but then the investment cost will jump quite a bit usually. not to mention that the swap kit can cost a good bit if you go with a jdm h22. you can always go with an american h22 for less, but they are hard to find (in my area at least).
learn to use the search feature in this forum. this topic has been beat to hell and back, and if you do a little searching and reading, you will find all the info and opinions you need.
275Performance
Apr 30, 2003 05:22 PM
bonker
45
Sep 18, 2001 08:41 AM
