car vibrates while braking only
Old Nov 14, 2007 | 12:14 PM
manualshft's Avatar
Default car vibrates while braking only
Does anyone know why it might be that my car vibrate when I brake. The steering wheel does not move, it feels like I'm running over little humps on the road. I notice it mainly at high speed braking incidents. I suspect it may be the brake disks, can anyone confirm or have an idea? Thanks.
Old Nov 14, 2007 | 01:01 PM
gulfview's Avatar
Default Re: car vibrates while braking only (manualshft)
It could be warped rotors or out of round drums.
Old Nov 14, 2007 | 01:17 PM
sony224422's Avatar
Default Re: car vibrates while braking only (gulfview)
yeah sounds like brake warp
Old Nov 14, 2007 | 01:56 PM
dang_erous's Avatar
somewhat same thing happend to me. had to get new brake pads and also the real reason was bc my rotors were so messed up i had to get new ones. you may be able to get your rotors resurfaced.
Old Nov 14, 2007 | 03:35 PM
Chiovnidca's Avatar
Default Re: car vibrates while braking only (dang_erous)
Pull up lightly on the ebrake to check if it's from the rear.
Old Nov 14, 2007 | 03:47 PM
accord_2dr's Avatar
Default Re: car vibrates while braking only (Chiovnidca)
more than likely it is warped rotors...i say get new brakes and rotors...you will have to eventually unless your brakes are brand new
Old Nov 14, 2007 | 05:54 PM
PnX-R's Avatar
Hmm.. "That usually means you're not pressing down hard enough.."
.."vibration while braking...."
Don't you just hate those....? I hate it when I mash the pedal and it just sounds like it shakes, or I just feel it in the pedal.. But in your case, you could pull the E-Brake on the highway for a few seconds and release it to help diagnose it. If you hear a bunch vibrating noises, your rear rotors/drums are probably warped too.
As for your fronts, I've seen it warp and not even shake the steering wheel, just the pedal pulsates.. But usually if the pedal just pulsates, it's because the rears are warped. In your case, take it to the pros..
Old Nov 14, 2007 | 06:03 PM
shortlid's Avatar
Default Re: car vibrates while braking only (PnX-R)
Does a '99 EX Accord use the rear caliper for the rear brakes or is it the rear drum inside the rotor.
Old Nov 14, 2007 | 06:17 PM
PnX-R's Avatar
Default Re: car vibrates while braking only (shortlid)
No it doesn't have the shoes inside the rotor. If you pull the E-Brake on that model, it just pulls the cable at the end of the caliper, thus making it easier to diagnose warped rear rotors..
Old Nov 14, 2007 | 06:32 PM
shortlid's Avatar
Good too know, thanks. So I guess I should not use the e-brake if the brakes are real hot may warp them locked with the pads in one spot on the rotor.
Old Nov 14, 2007 | 06:38 PM
PnX-R's Avatar
Your brakes aren't going to lock up or anything, at least I haven't seen it yet.. But regardless of what you do, if your rotors are warped, they're warped.. Can't post pone the warping (is that even a word) , if that's what you're trying to get at.
But do take the "apply e-brake on hwy" idea lightly. Don't crash or anything, I'm responsible for your wannabe behavior.. And don't pull to hard. Sometimes you'll hear the warped rear rotors, but yet you'll never feel them after resurfacing the front rotors.. It's sort of a trial and error ordeal at times.
Old Nov 14, 2007 | 11:34 PM
sony224422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnX-R &raquo;</TD></TR><TR><TD CLASS="quote">Hmm.. "That usually means you're not pressing down hard enough.."
As for your fronts, I've seen it warp and not even shake the steering wheel, just the pedal pulsates.. But usually if the pedal just pulsates, it's because the rears are warped. In your case, take it to the pros..</TD></TR></TABLE>
when you're saying this, are you meaning the the rears as in rotors or drums?
Old Nov 15, 2007 | 12:18 PM
josephcitr's Avatar
the vibration is be cause by the rear brakes either drums or rear disk
Old Nov 15, 2007 | 04:16 PM
PnX-R's Avatar
Default Re: car vibrates while braking only (sony224422)
Hmm.. Well, warped rear rotors or drums can cause a vibration while braking. It's usually easiest to diagnose warped rears by applying the E-brake while on the hwy. But, with some of the newer hondas, the E-brake is built into the rear rotor. Thus eliminating that way of diagnosing.
Old Nov 15, 2007 | 05:13 PM
sony224422's Avatar
interesting. what if the pedal shakes and so does the wheel?
mrdeadman
Aug 3, 2005 07:28 AM
icedlee
May 6, 2005 03:54 AM
Import_Fan
Apr 13, 2005 09:46 AM
digital sol
Oct 31, 2004 02:31 PM
dip-set
Jul 15, 2003 02:45 PM
