gsr turbo cometic head gasket
Old Nov 14, 2007 | 09:14 AM
proda9driver's Avatar
Default gsr turbo cometic head gasket
i have a gsr with arp head bolts cometic head gasket blox intake manifold im going to turbo it very soon what do you guys think about the cometic head gasket.
hel me out here guys i need suggestions Thanks
The cometic head gasket is .30 mm
Old Nov 14, 2007 | 09:49 AM
Dartanian's Avatar
Default Re: gsr turbo cometic head gasket (proda9driver)
OEM > dog poop > Cometic
Old Nov 14, 2007 | 10:10 AM
Mr. Anderson's Avatar
From: A gas station with 87, 89, 91, 92, 93 octane, FL
I'm currently using a cometic gasket (84mm, non-turbo) + hylomar (race formula/aerosol) on my boosted GSR.
I will never use a cometic hg again without it.
When I purchased my most recent cometic gasket I was told the turbo version was discontinued.
Old Nov 14, 2007 | 10:29 AM
PrecisionH23a's Avatar
The only time I run a cometic is if it is an extremely large bore or the head/deck has been milled. I use OEM on all of the 600+whp set-ups that I do and they work great.
Old Nov 14, 2007 | 01:40 PM
Dc2 Joe's Avatar
Default Re: gsr turbo cometic head gasket (PrecisionH23a)
im using a stock spec cometic head gasket. when i take off the head this winter i will be switching to a oem one. i have a had no problems with the cometic yet. but i dont wanna take the chance
Old Nov 14, 2007 | 02:49 PM
Hybrid_Coupe's Avatar
Id Like To know What everyones problem with the cometic is...everyone says not to use one..but not why. Ive been on the same cometic hp for 2 years...no blown head gaskets, no issues whatsoever...So From me Cometic HP's Which from what ive been told are discontinued, get a+. BTW this is a 700hp motor that has been through 3 different turbos...all the way from 520hp on a 60-1 up to its current setup on a gt40r
Old Nov 14, 2007 | 04:26 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
aren't Golden eagle head gaskets just oem gaskets bored out?
Old Nov 14, 2007 | 04:45 PM
mtber's Avatar
Default Re: (tannerLSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt &raquo;</TD></TR><TR><TD CLASS="quote">aren't Golden eagle head gaskets just oem gaskets bored out?</TD></TR></TABLE>
Supposedly
Old Nov 14, 2007 | 06:02 PM
mike93eh2's Avatar
Default Re: (Hybrid_Coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid_Coupe &raquo;</TD></TR><TR><TD CLASS="quote">Id Like To know What everyones problem with the cometic is...</TD></TR></TABLE>
cometic headgaskets have caused alot of problems for people.... oem has not. why not use oem? tell me that.. a whole lot cheaper as well.
Old Nov 14, 2007 | 08:52 PM
Ive had no problems. and the cometic wasnt that much more than a stock...Plus i like the ring. I mean we could ask a lot of why question, why step deck? why o-ring? why use a copper headgasket like ive seen some people do? I asked why people had problems with the cometics, and no one has come up with an answer besides "people have had problems". And i stated that My 700hp motor has been together for 2 years with a cometic headgasket, and no problems. So instead of bash a product, why dont you guys give real advice. Get back on the OP's topic.
Old Jan 8, 2008 | 09:14 PM
CBR_15's Avatar
Default Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">
cometic headgaskets have caused alot of problems for people.... oem has not. why not use oem? tell me that.. a whole lot cheaper as well.</TD></TR></TABLE>
But what about people who want to run .5mm bore over?? I doubt oem hg can accomodate that.
Old Jan 8, 2008 | 09:26 PM
champLSinteg's Avatar
Default Re: (CBR_15)
I am currently running a cometic on my 83mm with 400+whp and no problems yet. It was annoying trying to get it over the dowel pins though, I wish they would make those a tad larger.
Old Jan 9, 2008 | 03:49 AM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBR_15 &raquo;</TD></TR><TR><TD CLASS="quote">
But what about people who want to run .5mm bore over?? I doubt oem hg can accomodate that.</TD></TR></TABLE>
then you use a golden eagle headgeasket which is a oem gasket bored out to different sizes.
Old Jan 9, 2008 | 08:36 AM
Dunc's Avatar
BCICAN
https://honda-tech.com/zerothread?id=2083018
^^^Click. It's not an "offical" review so guys don't get your panties in a bunch trying to pick it apart. With that said, I still believe whole-heartedly that cometic gaskets are not up to par.
OEM
GE
Cometic
Old Jan 9, 2008 | 02:13 PM
CerealKiller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
Supposedly </TD></TR></TABLE>
Yes their OEM gaskets, Bored out to different specs. and have vtec dowel holes opened.
Old Jan 9, 2008 | 05:22 PM
PHDZINE's Avatar
Default Re: gsr turbo cometic head gasket (Mr. Anderson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Anderson &raquo;</TD></TR><TR><TD CLASS="quote">I'm currently using a cometic gasket (84mm, non-turbo) + hylomar (race formula/aerosol) on my boosted GSR.
When I purchased my most recent cometic gasket I was told the turbo version was discontinued.</TD></TR></TABLE>
I never knew they made a turbo version Headgasket...you sure its not the HP version with the thicker ring around the sleeves (not the Fuzion). The Cometic HP gaskets aren't made to be used with aftermarket sleeves.
I use nothing but Cometic Headgaskets with 40+PSI and over 800WHP and no problems! There are lots of variable that lead to headgasket failures like warped head, warped block, sleeve sank, bad tune, ETC. Most people assume its the gasket.
Old Jan 9, 2008 | 08:23 PM
Garcia-Racing's Avatar
We only use Cometics HGs on our racecar. Nothing bad to say about them.
Cho0se
Feb 24, 2020 02:59 PM
Jokerchris
Mar 21, 2015 01:42 PM
Joeski99Si
Apr 23, 2009 05:24 AM
jdm_h22
Aug 30, 2008 08:06 PM
Lmgrcivic
Feb 6, 2005 04:55 PM
