IACV cleaned, idle dropped??
Old Nov 14, 2007 | 06:41 AM
BDogggUT34's Avatar
Default IACV cleaned, idle dropped??
I cleaned my IACV according to other threads using some carb cleaner, and installed everything back the same way. I've done this before with no problems, but this time it made my idle drop. It will go to about 100rpms and then after about 10 sec make its way back up to 700-800. What could have went wrong? Is my IACV bad now? From searching i thought it was supposed to raise the idle, not lower. Motor is B18b turbo, Hondata S200b. Thanks
Old Nov 14, 2007 | 07:01 AM
BDogggUT34's Avatar
Default Re: IACV cleaned, idle dropped?? (BDogggUT34)
eehhh, searching more i found that i didnt bleed the coolant system. Gonna try that.
RinzEG6
Nov 24, 2014 12:02 PM
99blusi
Sep 6, 2007 01:48 AM
88da3
Nov 17, 2005 07:34 PM
slimbo
May 16, 2004 10:57 PM
