NEED HELP: Mounting Volk Racing Group C onto 93-95 civic coupe
Old Nov 14, 2007 | 06:27 AM
EJ2-Fluffy's Avatar
Default NEED HELP: Mounting Volk Racing Group C onto 93-95 civic coupe
Just picked up an awesome set of rims, however. How do you go about mounting these things on? The adapter plate which include the hubcentric ring holds the rim to the hub in the right spot. However, now the wheel studs are too short. (I know, extended wheel studs are on order).
The problem is how do you go about getting the right lug nuts to go on the rim and fit it to where the caps can screw on!
TIA,
Jon
Old Nov 14, 2007 | 08:21 AM
Kegan's Avatar
Get a set of open ended tuner lugs and you'll be just fine.
Old Nov 14, 2007 | 12:34 PM
EJ2-Fluffy's Avatar
Open ended set of nuts?
Thanks!
Anyone else, any lug nuts that will actually be smaller then the tuner lug nuts (rays, muteki, gorilla)?
The hole is physically smaller. Maybe Ill take it to a shop to get it bigger and tapered
Old Nov 14, 2007 | 12:49 PM
nix94delsol's Avatar
Default Re: (EJ2-Fluffy)
i used a regular ratchet and found out the size of the nut, and stuck it in, reefed on it, and i was fine
Old Nov 14, 2007 | 02:20 PM
r.wright's Avatar
Default Re: (nix94delsol)
u need to get some smaller acorn nuts that sit flush onto the adapter then mount the wheels onto the adapter
Old Nov 14, 2007 | 02:38 PM
Folgers's Avatar
Default Re: (Opossum Jenkins)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opossum Jenkins &raquo;</TD></TR><TR><TD CLASS="quote">u need to get some smaller acorn nuts that sit flush onto the adapter then mount the wheels onto the adapter </TD></TR></TABLE>
Got mine at walmart. **** works like a champ.
wallyworld
Old Nov 14, 2007 | 04:06 PM
EJ2-Fluffy's Avatar
The supplied VR lugs w/ keys keep the wheel mounted onto the adapter.
Normal open ended lug nuts keep the adapter mounted to the hub?
Old Nov 14, 2007 | 07:12 PM
r.wright's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ2-Fluffy &raquo;</TD></TR><TR><TD CLASS="quote">
Normal open ended lug nuts keep the adapter mounted to the hub?</TD></TR></TABLE> yes
Old Nov 14, 2007 | 08:40 PM
2ndlife's Avatar
what's the size and offset on those? are they going to fit on a civic?
Old Nov 15, 2007 | 03:28 AM
r.wright's Avatar
Default Re: (2ndlife)
without adapter: +44 offset
w/ adapter: +34 offset
15x6.5 4x100
Old Nov 15, 2007 | 05:47 AM
EJ2-Fluffy's Avatar
awesome ralpho =P Got it covered. You da man!
Old Feb 7, 2009 | 03:10 PM
fitfreak3's Avatar
Default Re: NEED HELP: Mounting Volk Racing Group C onto 93-95 civic coupe
I have these same wheels in 17's and you need this http://www.evasivemotorsports.com/me...tegory_Code=L1
justBrowsing
May 1, 2012 06:29 PM
hinpr18
May 8, 2009 09:41 AM
boostincoupe
Jun 30, 2008 06:03 PM
RalliartRsX
Suspension & Brakes
Nov 30, 2005 04:11 PM
TurboLude97
Feb 20, 2003 12:37 PM
