1991 crx seats in my EF hatch (91)
Old Nov 14, 2007 | 04:13 AM
B SERIES US's Avatar
Default 1991 crx seats in my EF hatch (91)
I just need to know what all needs to be done in order to fit CRX seat in my 1991 hatch?or if it can be done?
Thanks.
Old Nov 14, 2007 | 04:28 AM
CRX Toad's Avatar
Default Re: 1991 crx seats in my EF hatch (B SERIES US)
Yes it can be done. Just swap the seat pans and you'll be done. You know the the Si seats will bolt directly in from the same year (s) car.
Old Nov 14, 2007 | 07:16 AM
zachvirus's Avatar
hmm when i put my seats in from a 91 crx si it didnt fit at all, so i just did a little drillin
Old Nov 14, 2007 | 08:17 AM
503_EF9's Avatar
Default Re: 1991 crx seats in my EF hatch (zachvirus)
drilling is bad....
the guy who installed the del sols in my current project just drilled and drilled and finaly after about three missess he got them in gotta love that ****.
same year seats from civics will always swapp into same year civics.
same for crx's
Old Nov 14, 2007 | 07:07 PM
zachvirus's Avatar
Default Re: 1991 crx seats in my EF hatch (503_EF9)
then i prob got sent a different year. and i didnt mess up the first time. i was very cautious and sharpied a billion times
Old Nov 14, 2007 | 07:49 PM
philkehn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 503_EF9 &raquo;</TD></TR><TR><TD CLASS="quote">drilling is bad....
same for crx's
If it took him that long and he put that many holes in your car I am hoping for your sake he did this at no charge... This is just me assuming that he charged you and said he could do it... then he couldnt measure... i put aftermarket seats in my old dc.. I had to drill new holes got the seats in first try with a good measurement
If im not mistake you just swap the rails of the crx seats with the rails off your civic seats
Old Nov 14, 2007 | 08:52 PM
503_EF9's Avatar
Default Re: 1991 crx seats in my EF hatch (philkehn)
pfff
i didnt pay him to do ****
i bought the car this way haha
first order of buisness
rip the del slow seats out and swapp em for some sirs
Old Nov 15, 2007 | 02:49 AM
rd91sib18c5r's Avatar
crx seats don't fit civics only 2 bolts line up and they sit angled in.
If you like the gangster lean they are fine.
Old Nov 15, 2007 | 09:43 AM
lmananT's Avatar
Default Re: 1991 crx seats in my EF hatch (rd91sib18c5r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rd91sib18c5r &raquo;</TD></TR><TR><TD CLASS="quote">crx seats don't fit civics only 2 bolts line up and they sit angled in.
If you like the gangster lean they are fine. </TD></TR></TABLE>
this is true. no matter what anybody says, civic and crx seats are NOT interchangable even with seat pan swaps. repeat, they do not and will not FIT!
Old Nov 15, 2007 | 06:51 PM
zachvirus's Avatar
Default Re: 1991 crx seats in my EF hatch (lmananT)
thought so. the brackets are flat on the back of the crx seats anyways. where as the civics are bend to go with the frames bolt holes
Old Nov 18, 2007 | 07:18 AM
philkehn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmananT &raquo;</TD></TR><TR><TD CLASS="quote">
this is true. no matter what anybody says, civic and crx seats are NOT interchangable even with seat pan swaps. repeat, they do not and will not FIT!</TD></TR></TABLE>
Ive seen hatches with si seats before... with a rail swap
Old Nov 18, 2007 | 07:32 AM
racintweek2's Avatar
please quit spewing BS. i have a set of 90 crx Si seats in my 91 hatch using the stock hatch pans/rails and everything lines up perfectly
Old Nov 18, 2007 | 07:57 PM
lmananT's Avatar
Default Re: 1991 crx seats in my EF hatch (racintweek2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racintweek2 &raquo;</TD></TR><TR><TD CLASS="quote">
please quit spewing BS. i have a set of 90 crx Si seats in my 91 hatch using the stock hatch pans/rails and everything lines up perfectly</TD></TR></TABLE>
i have tried this on a 91 hatch seat into a 1988 CRX.
how is that possible when the crx pans mount on the sides and the civic hatch's pans have a metal piece protruding through the bottom cushion? i have personally done it myself and it will not fit anyway you put it unless you chop off some metal and re-weld.
KOOCHYOLOGIST
Jan 2, 2010 03:20 PM
ATL-EF squad
Aug 11, 2008 08:35 AM
steronz
Aug 18, 2005 04:53 AM
Thundakat85
Jul 1, 2005 02:55 PM
claytonsmith
20
Jun 1, 2004 04:06 AM
