Suspension & Brakes Theory, alignment, spring rates....
ground Control coilover problem
Old Nov 13, 2007 | 09:52 PM
tunerkid7's Avatar
Default ground Control coilover problem
so i was rollin on some 16s with tires that are smaller then suggested spec, when i upgraded to 17s with the reccomended tire size, i beleive as in i think, not sure it was 250 45 17, but anyways whenever i go over even the smallest bump my tires rub on my fender wells? i raised my coilovers as high as they go, but ive had problems with these coilovers since day 1. i ordered tokiko blues, they're on the way, im hoping this will help, anyfeed back what so ever would be greatly appreciated cause my neo gens are getting trashes, anyone else had problems like this or with ground control?
Old Nov 13, 2007 | 10:59 PM
slammed_93_hatch's Avatar
Default Re: ground Control coilover problem (tunerkid7)
250/45/17 is a huge freakn tire it is going to rub no matter what
Old Nov 13, 2007 | 11:04 PM
Emerica's Avatar
do you mean 255/45/17 ?
And yeah that is huge... i run 205's and they are plenty wide.
Old Nov 13, 2007 | 11:11 PM
tunerkid7's Avatar
Default Re: ground Control coilover problem (Emerica)
alright i'll check tomarrow, thats probably wrong sorry. I went omy uncles shop and when my car was on the lift we were able to just move my tire up and down with no resistance, would that be a shock problem??
Old Nov 14, 2007 | 07:36 AM
Crazydave's Avatar
Doesn't sound like a coilover issue... sounds like a rim/tire selection issue.
Have you tried rolling your fenders?
Old Nov 14, 2007 | 08:42 AM
Marauder's Avatar
Default Re: ground Control coilover problem (Crazydave)
With 17 inch wheels, you should be running a 205/40R17 tire if those 2002 civics are the same as my 2000
Old Nov 14, 2007 | 09:11 AM
tunerkid7's Avatar
Default Re: ground Control coilover problem (Marauder)
ive heard about rolling my fenders, ive heard there is a chance of doing some body damage, how do you roll your fenders? I'll try and post my tire size when i get home from school.
Thanks for the feedback so far guys
Old Nov 14, 2007 | 09:32 AM
Crazydave's Avatar
Do search there are writeups on this:
1.) Baseball Bat Trick
2.) Fender Rolling Tool
Old Nov 14, 2007 | 10:08 AM
Marauder's Avatar
I had my fender edges rolled. Have a professional do it, it shouldn't cost very much to do.
http://tom.actionfit.com/fenderolling.html
Old Nov 15, 2007 | 04:17 PM
tunerkid7's Avatar
oh thanks for the links, very helpful, who would do fender rolling? Midas, Les scwab? i dont just want anybody doing it, anybody have any suggestions?
Thanks again
Old Nov 16, 2007 | 04:06 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunerkid7 &raquo;</TD></TR><TR><TD CLASS="quote">oh thanks for the links, very helpful, who would do fender rolling? Midas, Les scwab? i dont just want anybody doing it, anybody have any suggestions?
Thanks again</TD></TR></TABLE>
If you have 205/45-17, that's also too big (you probably posted 250 instead of 205, there is no such thing as a 250mm section-width tire).
And Tokico HP shocks aren't going to help much. They're marginally better than OEM shocks and will not handle coilovers well at all.
Old Nov 16, 2007 | 03:17 PM
tunerkid7's Avatar
Default Re: ground Control coilover problem (PatrickGSR94)
uh oh i say that as i sit in my garage with 2 braqnd new tokico blues sitting in ffron of me, and ya my actual tire size is 215 40 zr17 87w, is it worth returning the shocks, or the $200 purchase plus probably $200 for install since i dont have a spring compressor?
And is it tire size, ive had so many problems with suspension and rubbing, i really appreciate all your help guys.
Old Nov 17, 2007 | 08:57 AM
tunerkid7's Avatar
any help would be great....
Old Nov 18, 2007 | 08:16 PM
tunerkid7's Avatar
nobody has ever had/hearad about this problem???????
Old Nov 18, 2007 | 08:54 PM
Tyson's Avatar
1. 250 width tires are REALLY wide tires. you havent even mentioned the offset of the wheels, which is also a primary factor in determining the placement of the tires and if they would rub or not.
2. blues suck. you should have read. you should have gotten illuminas.
Old Nov 19, 2007 | 12:06 AM
tunerkid7's Avatar
Default Re: ground Control coilover problem (Tyson)
i guessed in my first post, they are 215 and about the offset, im not sure nobody has said anything about them, i will check tomarow
thanks
tunerkid7's Avatar
oh and as for blues i heard good things about them but we'll see
Old Nov 19, 2007 | 04:13 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunerkid7 &raquo;</TD></TR><TR><TD CLASS="quote">oh and as for blues i heard good things about them but we'll see</TD></TR></TABLE>
haha read this, especially the last couple of pages https://honda-tech.com/zerothread?id=2040122
Old Nov 19, 2007 | 05:50 PM
tunerkid7's Avatar
dams shows you really cant trust the guys at autozone and your local performance shop eh?
On my car i have a 42 mm back spacing, thanks for all the help so far, looks like im goin to take those blues back
Ultraspeed DC2
Sep 21, 2008 10:19 AM
lsvtek
Suspension & Brakes
23
Apr 18, 2008 08:16 AM
xaznxdrgnxboix
Suspension & Brakes
10
Jun 8, 2007 10:13 AM
ILcrxsi1
24
Aug 22, 2006 06:34 PM
djay86
Jul 31, 2002 08:06 AM
