asr w/ skunk2 low arm bar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM.DEEBO »</TD></TR><TR><TD CLASS="quote">why do u say that?
ASR brace is more then enough to reinforce the rear sub frame, adding a skunk 2 tie bar is just going to make your ground clearance even worse.
</TD></TR></TABLE>ASR brace is more then enough to reinforce the rear sub frame, adding a skunk 2 tie bar is just going to make your ground clearance even worse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:Made in OC:. »</TD></TR><TR><TD CLASS="quote">
ASR brace is more then enough to reinforce the rear sub frame, adding a skunk 2 tie bar is just going to make your ground clearance even worse.</TD></TR></TABLE>
How does the Skunk2 LAB making ground clearance worse...
It's not even the lowest point on the suspension!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM.DEEBO »</TD></TR><TR><TD CLASS="quote">how is it going to make ground clearance even worse? its just a lower tie.
are you talking about a asr 22mm sway bar or asr brace? If your using a asr brace and trying to put a skunk 2 tie bar on it, its going to make clearance even worse. Do you get what im saying?
Like these people right here.
Even though the pic is not the skunk2, same ****.
This has been covered many times
FYI:
https://honda-tech.com/zerothread?id=2093230
The red search button really does work, I promise!
FYI:
ASR brace acts as a tie bar in itself, so any additional tie bar does nothing but add weight, in addition to any ground clearance issues there may be as previously stated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK24monster »</TD></TR><TR><TD CLASS="quote">
It's not even the lowest point on the suspension!!</TD></TR></TABLE>
x2 lol
x2 lol
very much so but ppl do it for bling. Theres a guy in the "post your lca and exhaust pics" thread that has asr, comptech, and beaks bar. talk about super overkill.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zum78spd »</TD></TR><TR><TD CLASS="quote">I might be a little new here, but why would you mount a Skunk2 on an ASR brace? Wouldn't it be pointless???</TD></TR></TABLE>
Yes I have stated that already.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zum78spd »</TD></TR><TR><TD CLASS="quote">Why would you mount a Skunk2 on an ASR brace? Wouldn't it be pointless?</TD></TR></TABLE>
Nate B
Jul 3, 2002 10:14 AM
