CTR Trans Vs. ITR Trans
Old Nov 13, 2007 | 08:18 PM
November's Avatar
Default CTR Trans Vs. ITR Trans
I have a GSR and my trans is on it's way out. I want to buy an ITR trans and there's someone selling a CTR trans.
Anyone help me with the differences between the two in terms of ratio and how it'll mount up to a B18. If I'm not mistaken CTR's have B16's, yes?
Modified by November at 10:48 PM 11/13/2007
Old Nov 13, 2007 | 08:39 PM
USDMCIVICHATCH's Avatar
Default Re: CTR Trans Vs. ITR Trans (November)
yes ctr is b16b and yes it will fit your gsr and yes you should get it
Old Nov 13, 2007 | 09:10 PM
silentrg03's Avatar
Default Re: CTR Trans Vs. ITR Trans (USDMCIVICHATCH)
The Ratios are the same for the CTR and ITR 96 Spec/USDM
3.230 2.105 1.458 1.107 0.848 3.000 4.400
Old Nov 13, 2007 | 09:34 PM
ghettocrxsi's Avatar
Default Re: CTR Trans Vs. ITR Trans (silentrg03)
The ctr trans will be a better allmotor trans, expect about a 4500 4800 rpm at 50 mph... Not good on the gas mileage but great for going quick.
Old Nov 14, 2007 | 07:26 AM
November's Avatar
Any idea how much I should expect to pay for one? I've seen ITR LSD's go for 1300. Not having much luck finding one on the marketplace.
Old Nov 14, 2007 | 07:41 AM
HYREV2NR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentrg03 &raquo;</TD></TR><TR><TD CLASS="quote">The Ratios are the same for the CTR and ITR 96 Spec/USDM
3.230 2.105 1.458 1.107 0.848 3.000 4.400 </TD></TR></TABLE>I thought the ITR/CTR trans were the same USDM or JDM except for the F/D. Am I incorrect on that?
Old Nov 14, 2007 | 07:42 AM
coolhandluke's Avatar
Default Re: CTR Trans Vs. ITR Trans (ghettocrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghettocrxsi &raquo;</TD></TR><TR><TD CLASS="quote">The ctr trans will be a better allmotor trans...</TD></TR></TABLE>
The CTR and ITR transmissions are the same in gearing, so this statement seems misleading to me.
Reference: ITR Gear Ratio
CTR & ITR Gear Ratios
OP: Len at Son's Acura can get you a brand new ITR transmission for around $1650:
http://www.sonsacuraparts.com/sons/jsp/home.jsp
Or, Call:
Len
770-968-5252
Old Nov 14, 2007 | 08:35 AM
Rdriver's Avatar
Default Re: CTR Trans Vs. ITR Trans (HYREV2NR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR &raquo;</TD></TR><TR><TD CLASS="quote">I thought the ITR/CTR trans were the same USDM or JDM except for the F/D. Am I incorrect on that?</TD></TR></TABLE>
The 98 spec has a 4.785 FD and shares the same 4th and 5th gear as the GSR. So you don't turn 4500 rpm's doing 65 on the HWY.
Old Nov 14, 2007 | 08:55 AM
HYREV2NR's Avatar
Default Re: CTR Trans Vs. ITR Trans (Rdriver)
So I'm guessing the 00/01 trannys have a different 4th & 5th?
Old Nov 14, 2007 | 09:03 AM
migs's Avatar
USDM ITR 97-01 = JDM CTR EK9
Old Nov 14, 2007 | 09:30 AM
SilverDc2's Avatar
Default Re: CTR Trans Vs. ITR Trans (migs)
USDM ITR & CTR
JDM ITR 98+
Old Nov 14, 2007 | 11:06 AM
HYREV2NR's Avatar
I know years ago I was planning on spending alot of $$ on gearing including the ATS 4.92 F/D. Then I got bit by boost. Looks like my USDM tranny will stay stock.
Old Nov 14, 2007 | 02:20 PM
pvt_awol's Avatar
Default Re: (HYREV2NR)
for what it's worth, I have a CTR tranny in my ITR. This is what I was told when I bought the car, and the code on the tranny matches what a CTR "should" have (then again, so does a standard B16 tranny) Mine DOES have the LSD also, so I assume it is legit. (short of tearing into it to count gear teeth)
anyway, when I go 75mph in 5th, I'm only at 4500 rpms.
Old Nov 14, 2007 | 09:30 PM
HYREV2NR's Avatar
Default Re: (pvt_awol)
If I'm not mistaken my ITR @ 80 MPH was spinning like 4K RPM's. Motor's been down for a while so I can't remember for sure.
If I were into the autocross thing I more than likely would have spent alot on gearing. I was always curious to know what my car would have run in the 1320 with an ATS 4.92 f/d. It's best times w/ just bolt-ons was like a 14.20 @ 98.6. Guess I'll never know.
Old Nov 14, 2007 | 09:43 PM
November's Avatar
I wouldn't need to get new axles, eh? This car eats my monies.
Old Nov 14, 2007 | 09:47 PM
GO-FIGHT-KILL's Avatar
Don't forget, the CTR differential is heavier than ITR.
Old Nov 14, 2007 | 10:14 PM
HYREV2NR's Avatar
Default Re: (GO-FIGHT-KILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget, the CTR differential is heavier than ITR.</TD></TR></TABLE>Why so?
Old Nov 15, 2007 | 06:42 AM
Nick MC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR &raquo;</TD></TR><TR><TD CLASS="quote">Why so?
</TD></TR></TABLE>To compensate for the ITR being heavier than the CTR of course!
Old Nov 15, 2007 | 06:52 AM
tartje's Avatar
Default Re: (Nick MC)
"I thought that what I'd do is that I'd pretend I was one of those deaf-mutes...
or should I?."
excellent laughing man quote
Old Nov 16, 2007 | 05:49 AM
Black R's Avatar
25 Year Member
COMPARE FOR YOURSELF:
http://www.ff-squad.com/tech/temp/Bgears.htm
Old Nov 16, 2007 | 06:27 AM
November's Avatar
Does the 5th gear of the ITR/CTR@0.848 really make that big a difference over the %th of the GSR@0.787?
Old Nov 16, 2007 | 06:33 AM
Black R's Avatar
25 Year Member
YES!
Devon M
Apr 12, 2016 04:11 PM
November
Nov 14, 2007 07:20 AM
eg6hatch94
Jan 25, 2006 12:26 PM
EF4lyfe
Jan 28, 2004 09:11 AM
