Car won't start!?
Old Nov 13, 2007 | 06:04 PM
jdmbeegee's Avatar
Default Car won't start!?
So i was driving my car(93 EG Hatch DX) just normal like every day and while driving the rpms dropped and the car shut off right away so i looked at the gas gauge and it showed Empty I thought i just ran out of gas so i added gas and ever since then i cant get it to start back up i have replaced the whole distributor, spark plugs and wires and still cant figure it out fuel pump is turning on and the main relay clicks so it seems that i am getting fuel because i can smell it I dont think I am getting spark. Need help! Fuses also looked fine.
Modified by jdmbeegee at 7:59 PM 11/13/2007
Old Nov 13, 2007 | 07:25 PM
dtapia's Avatar
Default Re: Car won't start!? (jdmbeegee)
how many miles on the motor and does it crank over faster then normal ?
if the timing belt broke their will be no spark or no start. easy thing to check is remove the oil cap and have some one crank it over and look at the rocker arm and see if it moves while the engine is been cranked over.
Old Nov 14, 2007 | 05:05 AM
jdmbeegee's Avatar
Default Re: Car won't start!? (dtapia)
the timing belt is still intact but has jumped timing I believe so out with the d15 in with a b series
Tr0LL
Sep 24, 2008 04:40 AM
nighttrain33
Mar 23, 2008 01:38 PM
dc2doi
Jan 6, 2008 01:43 PM
squirrelrun
Feb 8, 2006 05:36 PM
I3ackfire
22
May 14, 2004 09:50 AM
