where are you guys connecting braces to gt42r/S372?
Old Nov 13, 2007 | 05:58 PM
paulzy's Avatar
Default where are you guys connecting braces to gt42r/S372?
Where are you guys connecting braces onto the damn turbo? Both sides are vbands. I was thinking about welding tabs to the housings but maybe ask you guys first and see if you guys have an easier solution.
thanks
Old Nov 13, 2007 | 06:12 PM
PSI2HI's Avatar
Former Vendor
Default Re: where are you guys connecting braces to gt42r/S372? (paulzy)
Make some brackets to loop around the moutning bolts from the turbo to the manifold if you want wanna weld anything to the turbo itself.
Old Nov 13, 2007 | 07:30 PM
k24em2's Avatar
Default Re: where are you guys connecting braces to gt42r/S372? (PSI2HI)
You could TIG a bracket to the exhaust housing pretty easily
Old Nov 13, 2007 | 07:33 PM
paulzy's Avatar
Default Re: where are you guys connecting braces to gt42r/S372? (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">You could TIG a bracket to the exhaust housing pretty easily</TD></TR></TABLE>
that was my original idea and that will probably be what I end up doing.
Old Nov 14, 2007 | 04:34 AM
EdsGTI's Avatar
for smaller turbos with tighter housing bolt patterns people have used the 034 brace flanges
http://www.034motorsport.com/p...d=704
shown here.
Old Nov 14, 2007 | 05:43 AM
tony1's Avatar
Default Re: where are you guys connecting braces to gt42r/S372? (EdsGTI)
Just use a FR top mount and you don't need a brace.
Old Nov 14, 2007 | 07:09 AM
R@mon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EdsGTI &raquo;</TD></TR><TR><TD CLASS="quote">for smaller turbos with tighter housing bolt patterns people have used the 034 brace flanges
shown here.
that wouldn't work on the turbo's mentioned. they both have vband connections, no bolts.
Old Nov 14, 2007 | 08:28 AM
paulzy's Avatar
Default Re: where are you guys connecting braces to gt42r/S372? (tony1)
I'm not baller status enough to run F-R stuff though
I was contemplating not running a brace but that sucker is 42 pounds. That's a lot of weight compared to a t04S sized turbo.
Old Nov 14, 2007 | 02:23 PM
Crab-Cakes's Avatar
deff need to be a baller tho to buya 42R
Old Nov 14, 2007 | 05:26 PM
paulzy's Avatar
Default Re: (Crab-Cakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crab-Cakes &raquo;</TD></TR><TR><TD CLASS="quote">deff need to be a baller tho to buya 42R </TD></TR></TABLE>
very true, that's why I have an S372 instead, because I'm not ballin enough to afford a gt42r
Old Nov 14, 2007 | 06:37 PM
manifoldmiketyson's Avatar
theres a sequential gt42r kit for duramax's that use the oil drain bolt holes to mount the brace. i can't remembe if the drain and the brace were one though.
Old Nov 15, 2007 | 06:47 PM
bigTom's Avatar
you could try to make a mount for the turbo using another t4 flange.
Old Nov 15, 2007 | 10:11 PM
paulzy's Avatar
thanks for the idea Tom
Old Nov 16, 2007 | 02:27 AM
Tony the Tiger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulzy &raquo;</TD></TR><TR><TD CLASS="quote">I'm not baller status enough to run F-R stuff though
I was contemplating not running a brace but that sucker is 42 pounds. That's a lot of weight compared to a t04S sized turbo. </TD></TR></TABLE>
Should have purchased an HKS T51R turbo so you don't need a brace The T51R and 42R are similar, but the HKS unit weighs 20 lbs
Old Nov 16, 2007 | 05:45 AM
miller's Avatar
Default Re: where are you guys connecting braces to gt42r/S372? (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger &raquo;</TD></TR><TR><TD CLASS="quote">
Should have purchased an HKS T51R turbo so you don't need a brace The T51R and 42R are similar, but the HKS unit weighs 20 lbs </TD></TR></TABLE>
hmmmm
Old Nov 16, 2007 | 06:06 AM
.CUBISH.'s Avatar
Default Re: where are you guys connecting braces to gt42r/S372? (miller)
too bad the 372 that he has will destroy both.....
Old Nov 16, 2007 | 06:15 AM
miller's Avatar
Default Re: where are you guys connecting braces to gt42r/S372? (.CUBISH.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. &raquo;</TD></TR><TR><TD CLASS="quote">too bad the 372 that he has will destroy both..... </TD></TR></TABLE>
Old Nov 16, 2007 | 06:24 AM
BoostedJeff's Avatar
why that face?
Old Nov 16, 2007 | 07:55 AM
k24em2's Avatar
Dyno charts or ban
Old Nov 16, 2007 | 08:03 AM
.CUBISH.'s Avatar
maybe Tony1 will chime in on his experiences from switching from the 42 to a s372...
picked up around 100hp... and 6+mph in the quarter
Dyno charts or ban</TD></TR></TABLE>
How about proven with trap speeds.
Old Nov 16, 2007 | 08:10 AM
paulzy's Avatar
I know tony picked up a lot of power but I believe he's race compressor housing on his borg warner as well. I'm running a standard cover.
Old Nov 16, 2007 | 08:27 AM
Well, the 372 is a 72mm turbo compared to the 42 which is only a 70mm, of course it is going to make more power. The 372 with the standard 9" compressor cover flows 94lbs/min, almost 10lbs more than the 42.
Old Nov 18, 2007 | 11:48 AM
cvp467's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Just use a FR top mount and you don't need a brace. </TD></TR></TABLE>
JAJA same here
Old Nov 18, 2007 | 05:35 PM
mrbsponge's Avatar
you may need a new hood like me tho' hahaha
(not with the s371 and divided T4 manifold you wont) had to throw this in there
