lowering my car, which springs are best?
Old Jun 24, 2002 | 09:17 AM
braweebsta's Avatar
Default lowering my car, which springs are best?
I want the ride to be as smooth as possible. I'm not going to buy any coilovers just yet. I've heard eibach makes pretty good springs. Any ideas would be greatly appreciated.
Old Jun 24, 2002 | 09:20 AM
Flux's Avatar
Default Re: lowering my car, which springs are best? (braweebsta)
Why do you want to lower your car? Just looks?
Do you want stiffer springs for performance?
Old Jun 24, 2002 | 09:22 AM
braweebsta's Avatar
Default Re: lowering my car, which springs are best? (Flux)
I want them stiffer, but I also want it to look good without messing up the camber.
Old Jun 24, 2002 | 09:26 AM
Nate B's Avatar
Eibachs are great springs, H&R are good too, I have just upgraded my suspension to the Eibach pro-kit with Koni Sport shocks. Great looks and handeling.
Old Jun 24, 2002 | 09:39 AM
Flux's Avatar
Default Re: lowering my car, which springs are best? (KILLERB18)
I would recommend Spoon springs or kg/mm springs...
Old Jun 24, 2002 | 09:40 AM
hooptie157's Avatar
spoon springs (I'm still waiting for mine)
Old Jun 24, 2002 | 09:41 AM
Hybrid ctr's Avatar
Default Re: lowering my car, which springs are best? (hooptie157)
Spoon Springs
Old Jun 24, 2002 | 09:51 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: lowering my car, which springs are best? (Hybrid ctr)
love my sp00ms
Old Jun 24, 2002 | 10:04 AM
MPH's Avatar
MPH
New User
Stock
Old Jun 24, 2002 | 10:18 AM
RiCE On IcE 2's Avatar
wait u want a smooth ride also...but u want them stiffer... I dun think those to go together unless you meant something else.
Old Jun 24, 2002 | 10:39 AM
Andy_B's Avatar
Default Re: lowering my car, which springs are best? (scmdl26)
I'm glad this question has been asked. I'm new to the forum and was going to ask the same thing. I'm based in the uk with a Euro spec ITR and have had my eyes on the Spoon progressive rate springs (-20mm) and the Eicbach units, as well (-30mm).
What differences have people noticed with the Spoon units over the OE springs? Have they made high speed cornering more stable? As that is where I find the ITR to be less confidence inspiring with my style of driving........
AndyB
Old Jun 24, 2002 | 10:50 AM
Dave-ROR's Avatar
Default Re: lowering my car, which springs are best? (Andy_B)
spoons are a BIG drop.. I'd say 1-1.5".. not 20mm.. at least not on RealTypeR's car..
Old Jun 24, 2002 | 10:58 AM
brownman72000's Avatar
If the factory handling/suspension on the ITR is debated to be one of the best handling front wheel drive cars in the world, why do you people mess with the setup. The only thing I can see that you may get from it is the "lowered look." Im not saying that this is true but, it may be possible that by adding springs/coilovers, you car might handle worse. I know that for the s2000, they tested the eibach and some other good springs and foudn that both times, it made the handling worse than the stock setup. Also, you incounter so many problems when lowering...1. scraping and bottoming out. 2. people with CAI have a better chance of getting water in the engine. 3. you need to get struts and a camber kit in order for the tires to wear evenly and so that the factory struts dont blow. 4. You get a stiffer, bumpier ride. This is just my opinion. I had an SI with springs and all it did was cause problems. With my type R now, I am very content with the the handling. I just bought a set of s03's and I am thinkning about putting in the mugen rear sway bar. What are other peoples opinion on this topic? Thanks!
Old Jun 24, 2002 | 11:05 AM
uNF$@#!'s Avatar
Default Re: lowering my car, which springs are best? (brownman72000)
...you have that messed up a bit. its considered one of the best handling fwd cars in the world straight out of the factory.
Old Jun 24, 2002 | 11:24 AM
braweebsta's Avatar
how much will a full eibach pro kit cost me? (not installed)
Old Jun 24, 2002 | 11:33 AM
aet6's Avatar
For what its worth, I have the GC/Koni setup and feel that its just too stiff for street use.
It would be great for track use or if you really needed to change the ride height regularly.
However, the Koni shocks are noticeably better than stock.
My recommendation (what I'm going to do this weekend) is put the stock springs on the Konis.
With the Koni sports you can adjust the ride height to some degree (it has 2 perch settings).
My guess is the ride comfort will be closer to stock, but the cornering will be improved slightly.
The factory suspension IS set up well!
-aet
Old Jun 24, 2002 | 12:38 PM
Dave-ROR's Avatar
Default Re: lowering my car, which springs are best? (aet6)
-aet
Actually the suspension will react very slowly casuing a fairly harsh ride and poor performance. Adjustable Dampers are designed to adjust the damper to the spring rates and above or below depending on if you want the suspension to react slower or faster. What rate GC's do you have? If they are semi-high you probably exceeded Koni's low max spring rate. I run 450front/600rear springs on Bilsteins and it rides fine, not too harsh and not bouncy... obviously the ride will always be a little harder with increased spring rates.
The ITR does have a nice suspension from the factory, and most people on this board can't outdrive it, so my suggestion is to stay with the stock setup as well.. there is no CHEAP way to improve on the R's handling.. the cheapest would be GC's with custom rates and bilsteins (sorry, I love Bils) which would run you < 1,000.
The mugen rear sway bar is nice.. it owned me
Old Jun 24, 2002 | 01:06 PM
ITR #1202's Avatar
here is a good price on eibach prokit springs
http://www.modacar.com/Merchant2/mer...a&Carb=Integra
[Modified by ITR #1202, 5:07 PM 6/24/2002]
Old Jun 24, 2002 | 01:07 PM
Dave-ROR's Avatar
Default Re: lowering my car, which springs are best? (ITR #1202)
seems pricey..
maybe shox.com?
Old Jun 24, 2002 | 01:17 PM
Mr Hammond's Avatar
a/k/a Jomo
Not to be a dick, but this topic is what, say top 5 on the list of MOST ANSWERED QUESTIONS IN THE UNIVERSE! Search honestly does wonders. Takes less space and doesn't waste your time waiting for answers. Just a heads up.
o_Rage_o's Avatar
The mugen is 26mm or 24mm isnt it? It may cause some oversteer when its that large over stock
-Rage
Old Jun 24, 2002 | 01:26 PM
ITR764's Avatar
Default Re: lowering my car, which springs are best? (01_Yeller_ITR)
werd why would you want a lowered "look"????
Old Jun 24, 2002 | 01:31 PM
Champ R's Avatar
Personally I love the stock setup, but if you want to lower and improve the handling id go for spoon springs, although a bit pricey.
Old Jun 24, 2002 | 09:36 PM
SleepyR's Avatar
New User
If you could wait about a week I'm gonna be installing some kg/mm springs on my car. I'll let you know how I like them.
Old Jun 24, 2002 | 09:37 PM
01PYITR's Avatar
https://honda-tech.com/zerothread?id=215656
tkttran17
Honda Civic (2006 - 2015)
68
Nov 15, 2008 06:33 PM
seer
Oct 1, 2006 05:55 PM
SloazzEKhatch
20
Feb 7, 2004 05:02 PM
Phoenix_ITR
Apr 30, 2003 03:31 PM
sytema
Mar 25, 2003 01:49 PM
