a6 head gasket repair parts list
Old Nov 13, 2007 | 05:15 PM
coolusername's Avatar
Default a6 head gasket repair parts list
I have a d16a6 with about 145k on it and Im pretty sure the head gasket is gone. I was wondering what else I should replace while im in there. Heres a run down on what I think ill need, anything else i should need let me know. thanks
head gasket
thermostat
thermo gasket
water pump
timing belt
arp studs
Old Nov 13, 2007 | 05:21 PM
JimmyM86's Avatar
Default Re: a6 head gasket repair parts list (coolusername)
tensioner spring/pulley (not sure if its one piece or not)
check your other pullies to make sure the bearing are good...
Old Nov 13, 2007 | 05:45 PM
Default Re: a6 head gasket repair parts list (JimmyM86)
thanks
Old Nov 13, 2007 | 05:49 PM
gnar kill's Avatar
I alsways like to have an intake manifold gasket just in case the one on there doesn't come off nice.....if you take the intake mani off....I do it makes things easier....just make sure you get the surfaces really clean otherwise your idle will bounce all over the place
Old Nov 13, 2007 | 05:56 PM
JimmyM86's Avatar
Default Re: a6 head gasket repair parts list (gnar kill)
Same goes for the Exhaust....
I found its easy to leave the Intake manifold and Exhaust Manifold still in the car, so you don't have to worry about re-hooking up 500 vaccuum lines
both of those gaskets are cheap and should save you some head ache...just find something to support the intake and exhaust so you don't break any hoses or what not
I JUST got done doing this on my mazda...you'll have fun take your time and do it right and have fun learning!
Old Nov 13, 2007 | 07:21 PM
well i think im going to have to take the head to get check to see if its warped or not, so the intake and the exhaust will have to come off.
Old Nov 13, 2007 | 08:20 PM
JMsports's Avatar
Just pick up a complete gasket set. It will perform miracles in the future. usually when re-doing a head gasket, it requires a head set but for a couple more dollars, you can pick up a complete set and have it there as spares. Trust me, I might be a NOOB to this forum but ive been building engines at the machine shop for about 8 years now and it doesnt fail when kids come back and say, "I SHOULD HAVE LISTENED TO YOU. I TRIED BUYING INJECTOR SEALS AND THEY ARE ALMOST $30 ALONE." lmao. I think I have 2 D16A6/ZC gasket sets at the shop. PM or email me if you need it. Ill double check though.
TuPadre_01@Hotmail.com
Old Nov 13, 2007 | 08:26 PM
CRXDrew's Avatar
I've uses ebay gasket / belt kits on my sisters car and my parents car. Worked out great. Cheap too.
Old Nov 14, 2007 | 03:49 PM
JOE BD-0's Avatar
Default Re: (CRXDrew)
Why not use the HONDA factory head gasket upgrade kit with NEW bolts..............
Cylinder Gasket Kit:H/C ***0031
Kit includes:
Cylinder Head Gasket (new style)
P/N 12251-p01-004, H/C 4489530
and
Cylinder Head Bolts
(10 required, use with new-style gasket) these are spiral shaft to prevent stretching and are re-useable
P/N 90005-PM3-004, H/C 2894988
Good Luck.........
Old Nov 15, 2007 | 03:06 AM
Default Re: (JOE BD-0)
where can i get the honda gasket kit and bolts?
Old Nov 15, 2007 | 12:10 PM
JOE BD-0's Avatar
Default Re: (coolusername)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolusername &raquo;</TD></TR><TR><TD CLASS="quote">where can i get the honda gasket kit and bolts?</TD></TR></TABLE>
Same place you get yer dope........from the DEALER.........good luck.........
elmejor
Jul 17, 2009 03:45 PM
ilikejesus
Jan 17, 2009 10:59 PM
efyou
Jun 30, 2006 04:09 PM
rasinhell
Jan 24, 2005 09:44 AM
RS94
Feb 17, 2003 10:40 PM
