a6 head gasket repair parts list
I have a d16a6 with about 145k on it and Im pretty sure the head gasket is gone. I was wondering what else I should replace while im in there. Heres a run down on what I think ill need, anything else i should need let me know. thanks
head gasket thermostat thermo gasket water pump timing belt arp studs |
Re: a6 head gasket repair parts list (coolusername)
tensioner spring/pulley (not sure if its one piece or not)
check your other pullies to make sure the bearing are good... |
Re: a6 head gasket repair parts list (JimmyM86)
I alsways like to have an intake manifold gasket just in case the one on there doesn't come off nice.....if you take the intake mani off....I do it makes things easier....just make sure you get the surfaces really clean otherwise your idle will bounce all over the place
Re: a6 head gasket repair parts list (gnar kill)
Same goes for the Exhaust....
I found its easy to leave the Intake manifold and Exhaust Manifold still in the car, so you don't have to worry about re-hooking up 500 vaccuum lines https://honda-tech.com/forums/images/smilies/emwink.gif both of those gaskets are cheap and should save you some head ache...just find something to support the intake and exhaust so you don't break any hoses or what not I JUST got done doing this on my mazda...you'll have fun https://honda-tech.com/forums/images...es/emsmile.gif take your time and do it right and have fun learning! |
well i think im going to have to take the head to get check to see if its warped or not, so the intake and the exhaust will have to come off.
Just pick up a complete gasket set. It will perform miracles in the future. usually when re-doing a head gasket, it requires a head set but for a couple more dollars, you can pick up a complete set and have it there as spares. Trust me, I might be a NOOB to this forum but ive been building engines at the machine shop for about 8 years now and it doesnt fail when kids come back and say, "I SHOULD HAVE LISTENED TO YOU. I TRIED BUYING INJECTOR SEALS AND THEY ARE ALMOST $30 ALONE." lmao. I think I have 2 D16A6/ZC gasket sets at the shop. PM or email me if you need it. Ill double check though.
TuPadre_01@Hotmail.com |
I've uses ebay gasket / belt kits on my sisters car and my parents car. Worked out great. Cheap too.
Re: (CRXDrew)
Why not use the HONDA factory head gasket upgrade kit with NEW bolts..............
Cylinder Gasket Kit:H/C ***0031 Kit includes: Cylinder Head Gasket (new style) P/N 12251-p01-004, H/C 4489530 and Cylinder Head Bolts (10 required, use with new-style gasket) these are spiral shaft to prevent stretching and are re-useable P/N 90005-PM3-004, H/C 2894988 Good Luck......... |
Re: (JOE BD-0)
where can i get the honda gasket kit and bolts?
Re: (coolusername)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coolusername »</TD></TR><TR><TD CLASS="quote">where can i get the honda gasket kit and bolts?</TD></TR></TABLE>
Same place you get yer dope........from the DEALER.........good luck......... |
