H22 Stroker
Old Nov 13, 2007 | 05:12 PM
YingYangh22a1's Avatar
Default H22 Stroker
102mm stroke with a 90mm bore. All forged internals, and resleeve the block to accomadate the forged pistons. Would there be any problems here? I know most people don't recommend bore size over 89mm. And I've also been told if I turbo more displacement and such could help with turbo lag true?
Old Nov 13, 2007 | 06:10 PM
ethereal2pt2's Avatar
Default Re: H22 Stroker (YingYangh22a1)
if you plan on turboing this... you have *****.. i'll give you at least that. there are quite a few good threads on here about stroker kits. i'd give you a link but the search button isn't working for me right now.
Old Nov 13, 2007 | 06:11 PM
h23vtecpowered's Avatar
the bigger the bore the more compression. it would make since to stick with a standard bore. whats the point of going so big if your boosting.
Old Nov 13, 2007 | 06:20 PM
98vtec's Avatar
moderator emeritus
102 stroke?
Old Nov 13, 2007 | 07:25 PM
ilikehonda's Avatar
i wouldnt turbo something with a 90mm bore...cracked sleeve here i come
Old Nov 13, 2007 | 08:24 PM
2fastGSR's Avatar
King of the One Liners
Default Re: H22 Stroker (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">102 stroke?</TD></TR></TABLE>
exactly what i was thinking.....
Old Nov 13, 2007 | 08:29 PM
Default Re: H22 Stroker (2fastGSR)
102mm stroke 90mm bore.....thats what the kit from crower says....but the only difference between that kit and what i said is the crower kit for the h22 comes with a steel crank not a forged one
Old Nov 13, 2007 | 10:37 PM
Rosko's Avatar
damn you should be able to get more then enough power out of a stock bore/stroked setup. take a look at what md23vtec is doing. I'd leave the stroker kit for the n/a guys.
Old Nov 14, 2007 | 12:35 PM
mgags7's Avatar
Default Re: H22 Stroker (h23vtecpowered)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23vtecpowered &raquo;</TD></TR><TR><TD CLASS="quote">the bigger the bore the more compression. </TD></TR></TABLE>
Chris, fwiw, the two have no direct impact on one another.
OP: Don't waste your money on that kit, you'll make more than enough power on a well put together 90.7mm x 8xmm setup.
Old Nov 14, 2007 | 12:49 PM
Rosko's Avatar
Default Re: H22 Stroker (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
actually they do. compression is just a ratio of the volume between bottom dead center and top dead center. anytime you change the volume by either boring or stroking the engine you change that ratio. (assuming the same piston specs of course)
Old Nov 14, 2007 | 12:54 PM
mgags7's Avatar
I know that dude, I was just trying to say that is an over-simplification of it.
I think there are a lot of people on here that think an 11.5:1 piston will cause an 11.5:1 CR no matter what setup you have it in. Chris, I'm not directing that at you either mang.
Old Nov 14, 2007 | 01:33 PM
1700anddroping's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h23vtecpowered &raquo;</TD></TR><TR><TD CLASS="quote">the bigger the bore the more compression. it would make since to stick with a standard bore. whats the point of going so big if your boosting. </TD></TR></TABLE>
so he can blister the tires at 220mph...your r/s is going to suck big time.
your bearings won't last long at all i can grant you that.that rod is going
to look like a lawn mower rod.
Rosko's Avatar
Default Re: (mgags7)
gotcha matt, wasn't trtying to insult you
I wish they'd just give you the cc #'s rather then the compression.
mongtite
Oct 23, 2008 08:36 PM
lude98SH
Dec 6, 2006 11:39 AM
h22_crx
Apr 16, 2006 09:12 AM
h22turbolude
Mar 17, 2004 01:42 PM
fastludeh22
Aug 13, 2002 01:40 PM
