where is the fuel pump relay located 92-95 civics??
Old Nov 13, 2007 | 04:58 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default where is the fuel pump relay located 92-95 civics??
dont know if it matters but the car is a 93 cx.
I finished swapping in my b18 swap and cranked the car up, it ran as long as there was fuel in the fuel rail and quit. I didnt see the fuel gauge move so I figured it was out of gas. added 2 gallons of gas and no go. then I noticed I didnt hear any fuel pump whine at all.
I'm thinking that since the car had no drivetrain in it when I got it that probably the fuel pump/sending unit is bad and I'll have to swap the setup from my 93 dx into it to get it running. but on the off chance that the fuel pump relay is missing from the car (previous owner took lots of weird random things off the car) I would check that first. Is it under one of the seats?? or in the fuse panel under the hood??
never really needed to check before and it got too dark on me by the time I wanted to look around for it.
Old Nov 13, 2007 | 05:09 PM
jdmcivic1's Avatar
Default Re: where is the fuel pump relay located 92-95 civics?? (stackz)
next/under to the front driver side seat. by the gas/trunk latch, is where the relay is.
Old Nov 13, 2007 | 05:14 PM
instrument's Avatar
search "main relay"
if you hear it click there's no need to take it out.
but if you turn the key and hear no clicks, it would be my first stop.
Old Nov 13, 2007 | 05:27 PM
ejoner's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivic1 &raquo;</TD></TR><TR><TD CLASS="quote">next/under to the front driver side seat. by the gas/trunk latch, is where the relay is.</TD></TR></TABLE> Umm No its not, its in the drivers kick panel next to the fuse panel, gray box bolted up to the frame with a 10mm bolt.
bandit67
May 23, 2013 06:08 PM
Jap_Spec_Imports
Sep 10, 2008 01:43 PM
integraboi415
Aug 31, 2006 02:21 PM
crazygerman
Mar 4, 2006 11:57 AM
Dee A Nine
Aug 24, 2004 02:45 PM
