my buddys car is running like total $H!T help!
Old Nov 13, 2007 | 04:55 PM
vlc92189's Avatar
Default my buddys car is running like total $H!T help!
well.. he just got a ls hatch. supposively it has a valve train in it. well thecar has a valve tick. the idle is at 100. the guy that he bought the car from said its the tune thats makin the car idle so low, so we put a stock ls ecu in it.
now one question.. turning the idle screw to the left would that make it idle higher?
and when the valves get adjusted could that cause the idle to be fixed?
thanks guys
Old Nov 13, 2007 | 06:53 PM
Endo-land's Avatar
LSs are notorious for the valve adjust screw coming loose, had it totally come off on mine, luckily didnt damage anything, I just put it back on and did a valve adjustment. Probably a shot in the dark though.
Old Nov 13, 2007 | 07:02 PM
vlc92189's Avatar
Default Re: (Endo-land)
when u are unscrewing it to the left would that bring the idle up?
Old Nov 13, 2007 | 07:05 PM
93egSLEEPER's Avatar
Default Re: (vlc92189)
yep...looser will make the idle higher.... if its the same as b16
Old Nov 14, 2007 | 06:52 AM
vlc92189's Avatar
Default Re: my buddys car is running like total $H!T help! (vlc92189)
alright, well were gonna adjust hte valves, due a tuneup, plugs, wires, dizzy cap and rotor. and mess with the idle screw
thanks
anyone else have any input?
James648405
Jun 1, 2010 12:32 PM
20ls01
Sep 13, 2007 08:08 PM
Hondapreludeg
Nov 23, 2005 05:03 PM
Marble
Nov 18, 2004 05:51 AM
Rhetoric
Aug 1, 2003 04:31 PM
