Brake fluid recommendations
Old Jun 24, 2002 | 09:04 AM
kenji's Avatar
25 Year Member
Default Brake fluid recommendations
What brake fluid would you guys recommend?
My ITR is used for daily driving and a couple autocrosses a month. I would like something that is locally available.
-kenji
Old Jun 24, 2002 | 09:05 AM
Dave-ROR's Avatar
Default Re: Brake fluid recommendations (kenji)
Castrol LMA
Ford Truck HD (whatever it's called now)
Motul
I would say ATE Superblue but Jason Franza said it's discontinued.
Old Jun 24, 2002 | 09:06 AM
yoshi234's Avatar
I shoot brides
also
Darkteg's Avatar
New User
Default Re: Brake fluid recommendations (01_Yeller_ITR)
Dot 5.1 Ferodo Racing or APRacing Dot 4
Back in Black's Avatar
Rather OG
ATE Gold is still available though
Old Jun 24, 2002 | 09:07 AM
Flux's Avatar
Default Re: Brake fluid recommendations (Jason Franza)
Motul 5.1
Dave-ROR's Avatar
Same shti, different color..
so add ATE gold 200 to my list.
Old Jun 24, 2002 | 09:14 AM
01PYITR's Avatar
Castrol LMA is fine for everyday and its readily availible.
Old Jun 24, 2002 | 09:20 AM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Re: Brake fluid recommendations (01PYITR)
If you really want ATE Super Blue you can still get it here www.stranoparts.com
Old Jun 24, 2002 | 09:27 AM
nsxtcjr's Avatar
New User
Default Re: Brake fluid recommendations (ReBornGSR)
I like Motul RBF 600 because it's fairly inexpensive ($10-12 for a half-liter bottle) and its boiling point is 57 degrees higher than ATE - that's a BIG difference.
Here are the dry and wet boiling points for many of the most popular brake fluids:
ARRANGED BY DRY BOILING POINT:
DRY:401F -- WET:284F --- DOT3 MINIMUM
DRY:446F -- WET:311F --- DOT4 MINIMUM
DRY:500F -- WET:356F --- DOT5 MINIMUM
DRY:502F -- WET:343F --- VALVOLINE SYNPOWER
DRY:509F -- WET:365F --- MOTUL 5.1
DRY:527F -- WET:302F --- AP RACING 551
DRY:536F -- WET:392F --- ATE SUPERBLUE/TYP200
DRY:590F -- WET:410F --- AP RACING 600
DRY:590F -- WET:518F --- CASTROL SRF
DRY:593F -- WET:420F --- MOTUL RBF600
DRY:610F -- WET:421F --- NEO-SYNTHETIC SUPER DOT 610
ARRANGED BY WET BOILING POINT:
Old Jun 24, 2002 | 09:45 AM
naturalvx's Avatar
Motul, I got a shitload of it if you need it.
Old Jun 24, 2002 | 09:48 AM
SoCal ITR's Avatar
Default Re: Brake fluid recommendations (naturalvx)
When (if?) I switch my lines, I'll be getting motul 600.
Old Jun 24, 2002 | 10:58 AM
gsr98vtec's Avatar
Default Re: Brake fluid recommendations (SoCal ITR)
ate super blue...love it
Old Jun 24, 2002 | 11:26 AM
TaboR's Avatar
New User
just avoid to use anyting thats more than DOT3
ur break system will be fine~ coz DOT4&5 have
too much silicon which will kill ur tubes and seals
and very soon ur breaking system will die~!
for street, autoX & road race DOT3 is more than
enough already. DOT4&5 are just wasting of ur $
and killing ur system.
Old Jun 24, 2002 | 11:31 AM
Flux's Avatar
Default Re: Brake fluid recommendations (FreddyR)
This does not apply to DOT 5.1...
Old Jun 24, 2002 | 11:59 AM
B18CXr's Avatar
get the Ford chit and forget it....
Old Jun 24, 2002 | 12:05 PM
Turtle's Avatar
B - who just flushed his brake lines last weekend.
EDIT: Go HERE for your Super Blue
[Modified by 401-2001, 4:12 PM 6/24/2002]
Old Jun 24, 2002 | 12:38 PM
nsxtcjr's Avatar
New User
Default Re: Brake fluid recommendations (Flux)
It doesn't apply to DOT 4, either. DOT 5 is silicone (not silicon) based brake fluid, or SBBF. DOT 3, DOT 4, and DOT 5.1 are non-SBBF.
DOT 4 and DOT 5.1 fluids are worth getting because they have higher boiling temperatures than DOT 3, so they won't boil at temperatures where DOT 3 will boil.
If you're interested in reading about the various requirements of the U.S. federal government for brake fluid composition and labeling, click here.
Old Jun 24, 2002 | 12:41 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Brake fluid recommendations (nsxtcjr)
http://www.ipdusa.com has ATE Super bl00 for $9.95 per liter. On sale (10% off) today through Wendesday. 1-800-444-6473
Pat, who says IPD is a Volvo shop, but won't mind Honda ***** ordering from there
Old Jun 24, 2002 | 12:44 PM
Dave-ROR's Avatar
That is very true.
I have noticed that you have to change Motul more often, which is why it's on the bottom of my suggestion list.. Kenji doesn't (well hasn't yet) tracked his car so there is absolutely no need for such fluid.. Ford chit or Castrol LMA are my two suggestions for his needs with ATE Gold/Super Blue (if found) when he starts tracking the car, or motul since you should change it every event anyways.
Old Jun 24, 2002 | 12:46 PM
yoshi234's Avatar
I shoot brides
LOTS OF GOOD INFO HEYA:
https://honda-tech.com/zerothread?id=91191
Old Jun 24, 2002 | 12:47 PM
ITR764's Avatar
Default Re: Brake fluid recommendations (Splat)
$10 i'll be a honda **** ordering some!!!
Old Jun 24, 2002 | 01:13 PM
nsxtcjr's Avatar
New User
I have not found that to be true.
After all, its boiling point is still higher than other brake fluids, even after a while as it accumulates moisture.
I'm not saying that changing brake fluid often isn't a good idea. I'm just saying that Motul doesn't need to be changed any more often than any other fluid.
And you CERTAINLY don't need to change it every event. I've gotten great results with Motul by flushing it once a year, at the start of each track season (roughly April-October).
[Modified by nsxtcjr, 4:15 PM 6/24/2002]
Old Jun 24, 2002 | 01:14 PM
rainmanEK's Avatar
big strong guy
Default Re: Brake fluid recommendations (ITR764)
castrol gt LMA works good, used in our formula car and can be bought almost anywhere and cheap! good luck, eric
Old Jun 24, 2002 | 01:20 PM
uncleben's Avatar
Where does the Motul 600 fall into this?
-Ben, who's brakes feel "mushy" after an hour on the track Saturday and just flushed with Valvoline Synpower from stock Honda fluid on Friday.
