Part list for auto to manual swap
Old Nov 13, 2007 | 12:46 PM
Prudz_lude's Avatar
Default Part list for auto to manual swap
I could not find any information on the parts needed to convert a 4th gen from auto to manual. What parts are needed?
i have a parts car right now that was 5speed and before i send it away i want to make sure i strip it of all the parts needed for the swap just incase i can only find a good deal on a black si and it turns out to be an auto.
Some info on how to do the actual swap would be nice as well. My guess is whatever i take apart on my 5speed it will just be a matter of putting it back in the same order. Of course with the addition of removing the auto crap from the car. Does that sound about right?
Old Nov 13, 2007 | 12:53 PM
mgags7's Avatar
I know you tried searching. so try again.
Specifically search under my name, and don't forget : "archived threads"
Old Nov 13, 2007 | 07:41 PM
Prudz_lude's Avatar
Default Re: (mgags7)
very nice. thank you. See if i knew it was under your name it would have been easier. It is not stickied in the faqs section
Old Nov 13, 2007 | 08:53 PM
h23prelude's Avatar
i just finished swapping my 4th gen, i took plenty of pictures and i am planning on doing a "write up" on how to do it,
heres a parts list, need more info? want some pictures? email me
redvalleymotorsport@hotmail.com
intermediate drive shaft
drivers side c/v
5-speed tranny, (m2s4)
slave cyl
master cly
hydraulic line
pedal and bracket
transmission bracket and bushing
shifter assy. with cables
NEW clutch
NEW flywheel
DEALER ONLY-flywheel bolts ($23.00)
DEALER ONLY-pressure plate bolts($8.00)
longer bolt for starter
5-speed starter motor (look the same, but the pinnon depth is different)
shift ****
shifter boot
3 qts HONDA M.T. trans fluid
NEW axle seals
Old Nov 13, 2007 | 08:54 PM
h23prelude's Avatar
sry my my email is
redvalleymotorsport@gmail.com
Old Nov 14, 2007 | 09:18 AM
Prudz_lude's Avatar
Default Re: (h23prelude)
thank you, you have been pm'd
NARFALICIOUS
Honda Civic (2001 - 2005)
Nov 14, 2009 06:01 AM
Jon at Titan
May 3, 2006 05:18 AM
deeweezy187
Mar 27, 2006 01:53 PM
axtran
Jan 24, 2006 06:42 PM
p.g.
Jun 14, 2002 11:14 AM
