got a JRSC but having problems, if you have one see if this has happend to you
Old Nov 13, 2007 | 10:50 AM
kidrolla's Avatar
Default got a JRSC but having problems, if you have one see if this has happend to you
ok got a JRSC on my obdo b16 in 90 civic hb. first i still have stock injectors and the pullys i got on prob dont make more then 3 pds max. did this to see if it worked before changing abunch stuff out. know the problem is after about driving 20 mins the car looses power if a push the gas quater the way down like its boging out. but i can barely push it and seems to pull fine.seems like once ipush it down the fuel gets cut off and when i let of car goes back to idel fine. onlydoes this after about 15-20 mins driving.also im throwing a code 6 and wont go away ive reset codes and everything and at first i did have the wrong plug on it.anyideas before i put some 450 cc on there and a bigger pulley or do you think thatwill fix it , just seems odd runing fine till 20 mins later and also cars seems to pull fine till the hi rpm range seems to die off . im guess cause the stock injectors.
se_hatchback
Aug 4, 2010 04:24 PM
ZCcivic91
Jul 8, 2008 01:57 PM
boostedteg15
Jun 3, 2005 12:46 AM
MooreBoost
Mar 8, 2003 09:32 AM
SC Si
May 7, 2002 08:13 PM
