92-95 Civic b18 Auto to Manual B-series Conversion + Cable Clutch Retention Swap
setup is a set of mounts for allowing you to convert your automatic 92-95 honda civic to a manual transmission b-series engine with cable transmission.
Also included is my custom made cable pull pedal assembly so you dont have to convert over to the expensive hasport cable/hydro conversion brackets OR locate all the parts for a hydro pedal assembly. Just drill/grind a hole in the firewall for the cable and you're done.
I am including the original hydro pedal for the clutch pedal frame though if you want to convert in the future to hydro useage. this just gets you up and running now and cheaper until you can save up and locate everything.
You will either need to weld a clutch pedal stop or just deal with the pedal coming up to near the bottom of the dash (I got used to it quick). I would have done this but my welder was stolen before I could do this.
I'm selling the entire setup for just a little more than I have in the innovative passenger mount itself which was $195 from innovative (call them if you dont believe me).
$200 shipped for everything you see. I'm also including the gas/brake pedal assembly as well even though it's not in the picture.
D16Y7EJ1
Dec 15, 2012 06:11 AM
96Dc2 GSR
Northeast (Sales)
Jun 22, 2012 09:34 AM
96Dc2 GSR
Jun 22, 2012 09:33 AM
