keeps blowing fuses???
Old Nov 13, 2007 | 03:53 AM
zccr-xsi's Avatar
Default keeps blowing fuses???
hey guys i know i been having tons a prblems latly with my crx/zc well i got it running but when i start it it runs for a few sceonds then shuts off.for some odd resaon it keep blowing the alternator solienoid vlave fuse located on number 14 10amp fuse.this car is really starting t0 **** me off now it seems like its fighting me the whole way.
Old Nov 13, 2007 | 07:58 AM
eggmygirl's Avatar
* B A N N E D *
From: Running Round At Night In Los Angeles Like A Crazy, Veva Mexco, Veva Mexco
Default Re: keeps blowing fuses??? (zccr-xsi)
wiring might be bad ... check over it
Old Nov 13, 2007 | 08:00 AM
Duane_in_Japan's Avatar
Disconnect the items that the fuse powers in case the component is bad and not the wiring, see if it still blows, do you know everything that this fuse powers?
Old Nov 13, 2007 | 08:28 AM
richboi's Avatar
i had the exact problem when i ran the zc in my Si....it was one of the wires on the harness that runs from the passenger's shock tower to the idle sensor....i think it was a black wire,..just look at yours and see if theres any blackness around the connections at the harness plug
Old Nov 13, 2007 | 01:43 PM
zccr-xsi's Avatar
it is in a hf chassis u think i should switch the 2 wires around.i read something on zcr about it but i used the hf engine harness,and they werte talking about the si engine harness
RMX_EF9
Aug 26, 2010 09:29 AM
Civichx1998
15
Oct 25, 2009 08:17 PM
Keydet08
Jan 11, 2009 02:36 PM
503_EF9
Audio / Security / Video
May 18, 2007 08:50 AM
SIRX
11
Jan 13, 2003 06:29 AM
