change a water pump without removing the crank pulley?
Old Nov 12, 2007 | 11:46 PM
tdizz07's Avatar
Default change a water pump without removing the crank pulley?
this kid wants me to put a water pump in his 93 accord but he doesnt want me to do the timing belt i dno why yet i havtn asked him but is it possible to do without taking the crank pulley off? could i get by with taking the valve cover off and then perhaps teh middle timing cover? ive never seen a f22 without the cover or where the covers are lol
Old Nov 13, 2007 | 12:16 AM
tdizz07's Avatar
Default Re: change a water pump without removing the crank pulley? (Mr Wonderfull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull &raquo;</TD></TR><TR><TD CLASS="quote">Covers coming off man.</TD></TR></TABLE>
im worried about the crank pulley lol
Old Nov 13, 2007 | 03:00 AM
GhostAccord's Avatar
Default Re: change a water pump without removing the crank pulley? (tdizz07)
Can you tell me why this kid wants you to do this for him? After seeing you type this "I've never seen a f22 without the cover or where the covers are" I wouldn't let you wash my car let alone touch the engine.
Old Nov 13, 2007 | 03:36 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: change a water pump without removing the crank pulley? (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">Can you tell me why this kid wants you to do this for him? After seeing you type this "I've never seen a f22 without the cover or where the covers are" I wouldn't let you wash my car let alone touch the engine.</TD></TR></TABLE>
ah, come on now, thats a bit harsh don't you think? Just because he hasn't worked on one doesn't mean he cant do the work or have a manual that'll show him the proper procedure (but I guess that may be a stretch because if he did he wouldn't be asking ). But he is here looking for advise so lets play nice
Anyways, tdozz07, what Mr Wonderfull was saying was that the covers need to come off. Therefor since the covers need to come off then obviously the crank pulley has to come off to remove the lower cover. Just take a look in the FAQ for the write-up on how to replace the timing belt and water pump, that'll show you pictures of where things are located and the covers. Should help you see why the crank pulley needs to be removed.
Old Nov 13, 2007 | 05:11 AM
Default Re: change a water pump without removing the crank pulley? (TouringAccord)
My apologies, woke up on the wrong side of the bed this morning
Old Nov 13, 2007 | 06:08 AM
jamin's Avatar
more...since to replace w.p. requires removing timing belt-it connects to w.p.-and balancer belt one should reference touring accord writeup -this forum-esp. to break 180 ft lb crank bolt and the autozone.com howto specifically for the car model.
it is foolish to not replace timing belt unless just recently done.
also to replace w.p. requires removal of cam sprocket.
i just replaced my oe w.p. at 70k miles although it was like new.
btw, haynes was useful but a bit confusing to me at the same time.
Old Nov 13, 2007 | 07:09 AM
H-T Order of Merit
Default Re: change a water pump without removing the crank pulley? (jamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamin &raquo;</TD></TR><TR><TD CLASS="quote">also to replace w.p. requires removal of cam sprocket.</TD></TR></TABLE>
You are the second person to mention that recently, what year do you have? And are you able to get a picture showing why (I am curious)? I wonder if this is only for the F23 engine? I've never worked on a 98-02 so I dont know.
This isn't the case for the F22Bx's and I don't recall anyone saying this was necessary on the F22Ax's
Old Nov 13, 2007 | 08:43 AM
johnboy033's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
You dont have to remove the cam sprocket on the F23 either. I just changed the timing belt and water pump on my 99 I4 and did not remove the cam sproket. I don't really see how removing it would have made the job easier.
Old Nov 13, 2007 | 09:13 AM
H-T Order of Merit
so it doesn't "require" it to be removed then, ok.
Old Nov 13, 2007 | 09:34 AM
tdizz07's Avatar
dang, thanks for the info. if i woulda noticed tht link last night when i was lookin it woulda solved all my problems lol. thanks
amanrriquez12
Mar 9, 2009 01:10 PM
xak98x
Jul 6, 2007 10:29 PM
FOMULA91
14
Mar 23, 2005 07:26 PM
si_hatch
Dec 20, 2004 04:00 PM
hazman
Apr 8, 2003 06:28 AM
