Got motivated an opened an imagestation account....take a look
My little project car...hope this works
Front shot.....anyone see the I/C?
Side shot with my chick in the passenger seat...note the Mistubishi mirage rims
Custom 3'' Exhaust = Loud
Engine Shot -- this picture makes me dizzy
Turbo Shot -- Can anyone say clearance?
Skunk2 Intake mani w/ DSM 450cc injectors
[Modified by Speed PHreak, 4:40 PM 6/24/2002]
track times!
Also: you must have hella traction problems? What tires do you run on the street on the front?
[Modified by N8, 8:03 PM 6/24/2002]
Setup:
1988 CRX HF
Base weight -- 1816 lbs
15" rims (light-ish weight)
205/50/15 Falken's
10.3" Integra front brakes
Tokico Blues/Aero-speed Coil overs
Stock 17mm front sway bar
JDM / ITR style rear tailing arms
B18B
Fidanza Cam gears
Skunk2 Intake manifold
GS-R Girdle conversion
ARP rod bolts
ClutchNet Stage 2 clutch kit
1993 USDM YS1 transmission(LS)
Modified DRAG III turbo kit for a 94+ LS integra
Turbonetics T3/T04E .54A/R Stage III wheel
Spearco front mount I/C
Tial 35mm wastegate
HKS Super Sequential BOV
XS manual boost controller(set @ 10lbs)
DSM 450cc injectors
Custom oil return line made from hydraulic line
Custom closed loop dupe tube system
Zdyne SECU Gold
MSD 6AL
MSD Blaster Coil
MSD Pro cap
Focuz 9.3mm wires
NGK plugs
Autometer Boost, Water temp, Oil pressure, A/F gauges
Greddy turbo timer
Flex-a-lite slim line cooling fan
3" Custom exhaust
Focuz Highflow cat
Track times.....none as of yet. I mostly tool around late nights on weekends. Most of the domestic crowd at my local drop knows/knows of me. So I get match-ups every once in a while. Most are 5.0's on NOS or Blowers running mid/low 7's in the 1/8. Depending on traction, thats about the same as me, I'm alittle better on top-end due to wieght and the turbo factor
test
[Modified by Speed PHreak, 8:22 PM 6/25/2002]
1988 CRX HF
205/50/15 Falken's
B18B
Fidanza Cam gears
ARP rod bolts
Tial 35mm wastegate
DSM 450cc injectors
Zdyne SECU Gold
MSD 6AL
MSD Blaster Coil
MSD Pro cap
Focuz 9.3mm wires
NGK plugs
Greddy turbo timer
3" Custom exhaust
Focuz Highflow cat
. test
FS: rims, dizzy, turbo kits, injectors, suspension and bars, skunk2 intake mani, nitrous and more!!!
solfood
Northwest (Sales)
12
Feb 7, 2007 03:04 PM
solfood
Southeast (Sales)
14
Feb 7, 2007 03:01 PM
