b16 swap rear mount bracket help! searched all day...
searched 3 forums all day cant find a single pic this is my first swap b16 into ef i have a 90-93 bracket and i can not see were the bracket will mount to the engine . and will it be ok to mount drivers side and rear mount only tell i find a tranny? or should i just do it all at once thanx for your info
the rear bracket mounts to the trans, and i think its easier to put the motor n trans in at the same time. especially if it's your first one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaotickreationz »</TD></TR><TR><TD CLASS="quote">the rear bracket mounts to the trans, and i think its easier to put the motor n trans in at the same time. especially if it's your first one. </TD></TR></TABLE>Put the rear mount ON the crossmember and have the other two mounts on the trans and side. Do it all at once
I NEVER put pictures of my car on the internet. But I'll help you out since I'm in a festive mood.
There is no mount on the front crossmember. Just those three
awsome set up but i mean were the bracket ataches to the motor its self i cant seem to figure it out sry about the miss understanding
youll know it once you see it. i bought my engine from h motors and it was already on there. it goes on the back right where the engine and transmission meet. theres 3 bolts, one at the top coming from the transmission side and 2 at the bottom coming from the engine side,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alscrx »</TD></TR><TR><TD CLASS="quote">How come on your rear mount you didn't bend the rear crossmember lip under??? You get vibration cause it hits the rear bracket!</TD></TR></TABLE>
thats only with some mounts i never bent mine and it works fine. that rear mount will be a bitch to put on if the motors allready in but it can be done it sorta slips over the motor/trans. you should be able to see the mounting holes for the bracket.
str8up720
Sep 28, 2018 05:19 PM
Bob_760
Sep 7, 2006 08:50 PM
aaronhume
Feb 11, 2005 08:45 AM
