Searched still need help! ARP d16y7
Old Nov 12, 2007 | 08:32 PM
whiteknightef's Avatar
Default Searched still need help! ARP d16y7
I have a question, my y7 head swap onto my a6 block in my crx has fitment issues with the stock head bolts! The y7 head holes are too small? Is this normal in the y7 and y8 heads? Also if i need to get new head bolts what ARP ones do you guys think will work in the y7 holes?
I have searched so if you are here to flame me LEAVE! I will take your name to the moderator if you get out of hand!
Old Nov 12, 2007 | 08:53 PM
Default Re: Searched still need help! ARP d16y7 (whiteknightef)
anyone?
Old Nov 13, 2007 | 02:00 AM
mr.speaker's Avatar
1st of all, when bolting that head on the d16a6 block you need 9 a6 bolts and 1 y7/y8 bolt for the corner.
2nd,the bolts should fit through the holes,something's wrong
edit--I just looked, arp actually makes a kit that comes with the shorter bolt now,never had this before. http://shopping.lightningmotor...age=1
Old Nov 15, 2007 | 10:50 PM
Default Re: Searched still need help! ARP d16y7 (mr.speaker)
ok i'll re-check them and measure them. Then I'll post the measurements!
Old Nov 15, 2007 | 10:53 PM
so the y8 casting is really close to the y7 casting im guessing correct or no? i just want to order a kit and get the right stuff so im checking the fitment and any problems i might run into.
Old Nov 15, 2007 | 11:11 PM
mr.speaker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteknightef &raquo;</TD></TR><TR><TD CLASS="quote">so the y8 casting is really close to the y7 casting im guessing correct or no? i just want to order a kit and get the right stuff so im checking the fitment and any problems i might run into.</TD></TR></TABLE>
its the same thing as far as the holes go.
that link i posted for the arp studs will work,,i dont know why the bolts you have dont fit in the heads holes..
Old Nov 15, 2007 | 11:12 PM
ok well ill keep everyone updated! thanks for the link man that REALLY helps!
98ek9noboost
Jun 8, 2008 09:04 AM
1990si
Jul 21, 2006 05:21 PM
Twisted Image
Mar 23, 2006 08:59 AM
** OF HAZARD
Oct 13, 2003 06:41 PM
