TEIN hood dampers and Carbon Fiber hoods
Old Nov 12, 2007 | 08:08 PM
Thateguhate's Avatar
Default TEIN hood dampers and Carbon Fiber hoods
yay or nay?? I dont like working on my **** with the metal rod honda gives me becuase the hood forms an odd shape while up when the sun is beating on it..
The hood dampers would help prevent the deformation...but would cf be able to withstand the resistance of the damper/hoodshock??
anyone have any experience with this??
Old Nov 12, 2007 | 08:49 PM
Markland Photo's Avatar
I have read, that having the 'tien' hood dampers are not good for working with carbon fiber hoods. password jdm sells hood dampers that are specifically for carbon fiber hoods if i remember correctly.
I had tien dampers on my vis cf hood, no problems w/ the hood, but my damper did break on the top piece, maybe coincidence, idk.
i would buy the ones made specifically for cf IMO.
hope this helps.
Old Nov 12, 2007 | 08:56 PM
.:Made in OC:.'s Avatar
Default Re: TEIN hood dampers and Carbon Fiber hoods (Thateguhate)
those hood dampers piston is designed to lift metal hoods and not cf, it will probably break the cf if you do use it. For an alternative, iv seen people use only 1 hood damper for a cf hood it i heard it works fine.
Old Nov 12, 2007 | 10:34 PM
VersionUp's Avatar
Default Re: TEIN hood dampers and Carbon Fiber hoods (.:Made in OC:.)
not the greatest of ideas with a cheap quality CF stranded hood, like ViS. I've seen those TEIN hood dampers break those ViS hoods while the hood is down cause the damper, which is made for metal hoods, is constantly putting pressure and stress on the hood.
Old Nov 12, 2007 | 10:36 PM
Doostur's Avatar
Id at least go with Fiber Images or Spoon if your baller enough
Old Nov 13, 2007 | 05:56 AM
Default Re: (Doostur)
ok, well after reading all this I think I will pass... I dont wanna chance screwing up my decently shaped hood haha.. right on for the reviews!
Old Nov 13, 2007 | 07:17 AM
eggmygirl's Avatar
* B A N N E D *
From: Running Round At Night In Los Angeles Like A Crazy, Veva Mexco, Veva Mexco
Default Re: TEIN hood dampers and Carbon Fiber hoods (VersionUp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VersionUp &raquo;</TD></TR><TR><TD CLASS="quote">not the greatest of ideas with a cheap quality CF stranded hood, like ViS. I've seen those TEIN hood dampers break those ViS hoods while the hood is down cause the damper, which is made for metal hoods, is constantly putting pressure and stress on the hood. </TD></TR></TABLE>
yep i had that same set up and it broke 2 bolts and allmost broke the other side..
if you get them go with a metal hood!
OR A APC ONE
Old Nov 13, 2007 | 07:19 AM
91redteg's Avatar
Default Re: (Thateguhate)
the password jdm ones arent made speciffically for carbon fiber. they are made adjustable so u can release pressure to a point where it is ideal for carbon fiber or metal. and they look baller
Old Nov 16, 2007 | 03:41 PM
Hondaruss's Avatar
Default Re: (91redteg)
I made my own hood damper.. 55# strut a right angle mount bracket was 2 bucks and a half round slotted bolt and boom i can close my hood with one finger and i have a CF hood.
Old Nov 16, 2007 | 03:59 PM
mr.speaker's Avatar
Default Re: TEIN hood dampers and Carbon Fiber hoods (solbrothers)
https://honda-tech.com/zerothread/2152349 didnt work out for this guy,
Jamied
13
Jan 28, 2007 06:01 PM
dbros_ek
Aug 30, 2002 05:07 AM
redteg1
Aug 31, 2001 06:18 AM
RHGSR01
Aug 22, 2001 09:47 PM
