Tranny seal question
Old Nov 12, 2007 | 03:31 PM
nihad's Avatar
Default Tranny seal question
I have a problem with my dx tranny leaking fluid i am not sure where but want to ask can tranny fluid leak out of the shifter forks that go in side of the trans. Its allway greace oil around it. And is there a seal to buy to replace it.
Old Nov 12, 2007 | 06:36 PM
alscrx's Avatar
Default Re: Tranny seal question (nihad)
Well i just checked the diagram and don't see any seals.
http://www.hondaautomotivepart...SHAFT
Maybe your ordinary axel seal??
Old Nov 12, 2007 | 07:31 PM
brian...'s Avatar
there should be grease around the fork for the throw out bearing, other than that the only seal there is around there is the rear main.
Old Nov 12, 2007 | 08:03 PM
nihad's Avatar
Default Re: (brian...)
yeh the one in the back where the shift linkage connects to the shift forks with the bitch pin. It on the out side.
litoekneeil
Transmission & Drivetrain
Jun 8, 2010 08:53 AM
civicboisi
Nov 15, 2004 07:56 AM
SandFireTypeR
Nov 9, 2004 03:58 PM
B18CJDM ITR
May 31, 2004 02:03 PM
X2BOARD
May 10, 2003 09:29 PM
