b16a2 into 96 ex.....
Old Nov 12, 2007 | 03:29 PM
96electronH's Avatar
Default b16a2 into 96 ex.....
like the title says im in the process of saving money to buy a b16a2 for my 96 ex...i kno i need the linkage and a throttle cable bracket i think..? but i was wondering if it is plug and play with my ecu and harness?...and if i need new mounts or anything else to have it dropped in the right way!!!
just looking for advice and tips.
thanx
Old Nov 12, 2007 | 03:30 PM
http://www.osakajdmmotors.com/introhonda.htm
link for b16a2 i was looking at.
Old Nov 12, 2007 | 03:43 PM
nix94delsol's Avatar
Default Re: (96electronH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96electronH &raquo;</TD></TR><TR><TD CLASS="quote">http://www.osakajdmmotors.com/introhonda.htm
link for b16a2 i was looking at.</TD></TR></TABLE>
dont EVER buy ANYTHING from that site
there out of canada =P
http://www.hmotorsonline.com
^^^ go there, youll need b16 motor mounts, (or if you can find a 99-2000 civic Si that would be a plus) the axles, and wiring harness...as far as the ECU im pretty sure its plug and play...
Old Nov 12, 2007 | 03:45 PM
Default Re: (nix94delsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nix94delsol &raquo;</TD></TR><TR><TD CLASS="quote">
^^^ go there, youll need b16 motor mounts, (or if you can find a 99-2000 civic Si that would be a plus) the axles, and wiring harness...as far as the ECU im pretty sure its plug and play...</TD></TR></TABLE>
EDIT:
Requires engine, trans, ECU, OBD2 to OBD1 wiring jumper harness, axles, half shaft, shift linkage and 99-00 Civic SI rear engine mount.
Old Nov 12, 2007 | 03:52 PM
http://www.hmotorsonline.com/s...30004
does this look good for me?
civic542
Nov 5, 2007 01:15 PM
jeffk182
Aug 2, 2004 02:48 PM
topher
Jan 27, 2002 12:05 AM
