Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Brake Pedal Squeak
Old Nov 12, 2007 | 02:20 PM
Nighthawk7thGen's Avatar
Default Brake Pedal Squeak
Got another weird one for ya...
For about 6 months now...when I release a depressed brake pedal on my 2001 ES1 I get a squeak...just a meager mechanical squeak...
...so...whadda I need to grease up?
Old Nov 12, 2007 | 06:02 PM
01blackcivic's Avatar
i have an 01 too and have the same problem. I think i need to put more anti-squeal on the pads. Might not have put enough on in the first place. My truck did the same thing and taking the pads off and putting more anti-squeal on them did the trick.
Old Nov 12, 2007 | 06:37 PM
Shintakun's Avatar
the pedal??? ok well some WD-40 will do it... just go under there with a light and spray the end of the pedal (not where ur foot goes)
Old Nov 13, 2007 | 12:24 AM
toyomatt84's Avatar
Sanji
Default Re: (Shintakun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shintakun &raquo;</TD></TR><TR><TD CLASS="quote">the pedal??? ok well some WD-40 will do it... just go under there with a light and spray the end of the pedal (not where ur foot goes)</TD></TR></TABLE>
WD-40 is water-based. You'd be better off using an oil-based lubricant or Lithium Grease around the brake cable bushing.
Pabs626
Dec 9, 2007 05:02 PM
98savage
Apr 12, 2007 12:23 PM
josephshark
12
Dec 19, 2005 01:34 PM
m3dia_lab
Jun 4, 2004 06:52 PM
iperez
Jul 14, 2003 09:36 PM
