1992 prelude si- which alternator
Old Nov 12, 2007 | 02:10 PM
6doorsentra's Avatar
Default 1992 prelude si- which alternator
can i use another alternator off another vehicle? is any other one compatible?
Old Nov 12, 2007 | 02:24 PM
mattsnooz's Avatar
Default Re: 1992 prelude si- which alternator (6doorsentra)
92-96 preludes and...some accords I believe aswell. Some one else will know for sure. There are lots of other models that can be interchanged though.
Old Nov 12, 2007 | 02:26 PM
mattsnooz's Avatar
If you need one you should see if any aftermarket ones or performance ones are available. They are usually cheaper than Honda ones. But I take it your looking for a wrecker alternator
They will run you about 100$ usually with your core in exchange. Performance ones brand new might only run you 300$ to 400$ in some cases I believe. Someone correct me if I'm wrong about the pricing.
Old Nov 12, 2007 | 02:55 PM
im mostly concerned about whether a D series or B series will work on it.. from either an integra or civic
Old Nov 12, 2007 | 02:56 PM
mattsnooz's Avatar
Default Re: (6doorsentra)
oh, I don't think so personally, but i don't know for sure.
good luck man
Old Nov 12, 2007 | 02:59 PM
vinuneuro's Avatar
Default Re: (mattsnooz)
http://www.slhondaparts.com Cross-reference part number and see which ones will/won't work.
I doubt B alternators will work, as they mount at the rear those engines.
Old Nov 12, 2007 | 05:06 PM
snobordboy's Avatar
Moderator
I know explicit speed makes mounts to mount a d series alt on our motors, so I assume that it is different, although it may be more for the lower placement as well?
Old Nov 12, 2007 | 06:03 PM
Acidcrakker's Avatar
Default Re: (snobordboi)
I have an altenator off an h23 that you can have. Pm me if you want it.
martn53
Jul 6, 2025 11:16 AM
cheebang
Oct 4, 2009 02:35 PM
ej8_fredi
Sep 8, 2008 09:38 PM
Speedra500
Jul 10, 2006 07:30 AM
