What rings and bearing brands do you guys recommend?
Old Nov 12, 2007 | 02:07 PM
BLinindoll's Avatar
Default What rings and bearing brands do you guys recommend?
Well, the D15 I used to replace my D16y7 (not for performance reasons obvioustly) burns more oil now than the D16 did. I decided to rebuild the D16 which is sitting in my yard. I'm now looking to start to round up the parts. I dont really know what are good brands and what are garbage brands for these cars. (I'm a Chevy Camaro/truck guy and I'm just getting my nose into the Honda world.) What would you guys recommend for what I'm going to need? I'm basicly keeping it stock, cept for header and intake. Are there any little things I should do while its apart as far as little power boosters. i'm not looking for any race car by any means. Its a daily driver and I like my gas milage, so don't say high comp pistons or turbo. Just little things to add a few HP's. If there's nothing farely inexpensive to do, dont be afriad to say it. Thanks in advance.
Modified by BLinindoll at 8:39 PM 11/14/2007
Old Nov 12, 2007 | 02:09 PM
B16B_coupe's Avatar
HRD PKR
Default Re: What rings and bearing brands do you guys recommend? (BLinindoll)
well if your keeping it stock, you cant beat oem rings, bearings etc...
Old Nov 14, 2007 | 07:38 PM
BLinindoll's Avatar
Default Re: What rings and bearing brands do you guys recommend? (B16B_coupe)
ttt
Old Nov 14, 2007 | 07:52 PM
sauceja's Avatar
an efficient turbo can increase mpg. Its all in tuning.
OEM parts ftw. expensive but worth it.
Old Nov 14, 2007 | 09:45 PM
BLinindoll's Avatar
Default Re: What rings and bearing brands do you guys recommend? (sauceja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja &raquo;</TD></TR><TR><TD CLASS="quote">an efficient turbo can increase mpg.</TD></TR></TABLE>
Correct, BUT the cost of a complete turbo setup (done right) is much more money than the fuel it would save Not to mention the fact that the extra power of a turbo would def. make MY mpg worse. It would be hard not to drive it like it's turboed, lol. Thanks anyway.
I've been doin a little research and found that ACL race bearings and NPR rings are both pretty good bands. Havn't found one bad remark about ACL bearings. Compared to the cost of OEM, these sound pretty good. I've found that quite a few engine reman. places use these bearings too with no complaints. Anyone have any thoughts on these brands compared to OEM?
Old Nov 14, 2007 | 11:21 PM
Hardedge's Avatar
Sorry dude, I know the parts are expensive, but even if you're building a high horsepower street motor you still can't get better bearings and rings than OEM. That may not be the case with Chevy, I don't know, but Honda excells at all the little wear-out parts, especially rings.
Old Nov 14, 2007 | 11:28 PM
MR.johnson's Avatar
Default Re: (Hardedge)
oem is the best
Old Nov 15, 2007 | 12:08 AM
Phenol312's Avatar
ive heard a lot of good things about ACL bearings but for my build im definitely going with OEM.
Old Nov 15, 2007 | 02:11 AM
92ehatch's Avatar
Default Re: What rings and bearing brands do you guys recommend? (Phenol312)
also heard good things about acl and king bearings.
you can get acl from carquest.
Old Nov 15, 2007 | 04:01 AM
JKov240's Avatar
Default Re: What rings and bearing brands do you guys recommend? (92ehatch)
OEM
EDIT: Or King Bearings, as stated above
Old Nov 15, 2007 | 05:49 AM
Luserkid's Avatar
Default Re: What rings and bearing brands do you guys recommend? (JKov240)
OEM rings or Hasting rings. ACL bearings.
Old Nov 15, 2007 | 06:20 AM
98or00gsr's Avatar
Default Re: What rings and bearing brands do you guys recommend? (Luserkid)
i just bought je pistons/rings and clevite bearings for my turbo'd gsr
Old Nov 15, 2007 | 03:23 PM
sauceja's Avatar
Default Re: What rings and bearing brands do you guys recommend? (98or00gsr)
Did you guys know that the founder of honda started by making rings and rings only for motorcycles and racing back in the early days.
Ashaming that you guys don't know the history of the cars you hold so highly.
FOKAI95
Aug 1, 2012 08:19 PM
90LSpimpin
May 13, 2005 12:35 AM
TurBoTeG
Feb 10, 2004 08:14 AM
Hoosier Daddy
Sep 29, 2003 02:49 PM
turboteg96
Feb 11, 2003 06:48 PM
