Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Redlining at 3500....
Old Nov 12, 2007 | 10:19 AM
souljaboy's Avatar
Default Redlining at 3500....
I got an 02 civic ex and every once in a while (like once a week) it'll start running funny like the engine'll start stuttering and eventually stalling at lights and ****. also when i get on it it'll redline at 3500. if u got any ideas post em...
Old Nov 12, 2007 | 10:20 AM
Newborn_'s Avatar
Grace Under Pressure
Default Re: Redlining at 3500.... (souljaboy)
Souljaboy?
HAHAHAHAHAHAHAH!
Sorry... Ahem.
When did you last change your oil?
Old Nov 12, 2007 | 10:21 AM
Boilermaker1's Avatar
The rev limiter is safe mode, i would venture to say the CEL is also on, at which point, scan the code.
Old Nov 12, 2007 | 10:23 AM
Newborn_'s Avatar
Default Re: (Boilermaker1)
Yeah, what he said. ^
Old Nov 12, 2007 | 10:39 AM
toyomatt84's Avatar
Sanji
Default Re: Redlining at 3500.... (EM2_UK#1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM2_UK#1 &raquo;</TD></TR><TR><TD CLASS="quote">Souljaboy?
HAHAHAHAHAHAHAH!
Sorry... Ahem.
When did you last change your oil?</TD></TR></TABLE>
I would also recommend looking to see if your "check engine" light is on. Usually, when the car is in limp mode, the CEL will illuminate.
Old Nov 12, 2007 | 12:49 PM
souljaboy's Avatar
Default Re: Redlining at 3500.... (toyomatt84)
yea, the CEL is on...and would it be because of the need for an oil change?
and the name was just random...lol...
Old Nov 12, 2007 | 01:37 PM
Nighthawk7thGen's Avatar
I didnt know they made Civics with diesels in em...
redline at 3500...ahhh good ole safe mode
Old Nov 12, 2007 | 02:38 PM
1llmatic's Avatar
New User
Default Re: Redlining at 3500.... (Nighthawk7thGen)
crank dat souljaboy!
A CEL wouldn't turn on just because you need an oil change.
Old Nov 12, 2007 | 03:52 PM
civic04coupe's Avatar
Default Re: Redlining at 3500.... (1llmatic)
YOU!!!!! lol
Old Nov 13, 2007 | 12:25 AM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by souljaboy &raquo;</TD></TR><TR><TD CLASS="quote">yea, the CEL is on...and would it be because of the need for an oil change?
and the name was just random...lol...</TD></TR></TABLE>
When it says, "Check Engine", that usually means you need it serviced. Get an appointment with your local Honda Dealership as soon as you have time available.
Old Nov 13, 2007 | 01:11 AM
Newborn_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk7thGen &raquo;</TD></TR><TR><TD CLASS="quote">I didnt know they made Civics with diesels in em...
Well they do.
Old Nov 14, 2007 | 05:45 PM
PnX-R's Avatar
Hmm.. What do you mean by redline??.. Do you mean the engine won't rev past 3500rpm??..
I've seen one incident on that model year civic where it wouldn't rev past 3000 rpm or so with the check engine light on. Then when I shut off the car and started it up, the light was off and it idled for maybe 2 mins and the light came back on. I would shut it off and start it up again, but this time I revved it up and down then the light came on in like 30seconds of revving it.
Pulled the code, had a CKP performance/range problem and a CAM/TDC no pulse. Checked power, ground and reference signal at the sensor and confirmed the CAM/TDC sensor was cutting out after it got warm. Replaced the darn thing and the light stayed off and it ran fine.
So yeah, moral of the story.. Go pull that code..
WhiteOnRice
12
Apr 20, 2008 12:59 PM
SoftieB16
Jun 15, 2004 12:52 AM
HYBRIDHATCH92
13
Jan 22, 2004 06:15 AM
