Window popping off track?
Old Nov 12, 2007 | 10:14 AM
98ej8coupe's Avatar
Default Window popping off track?
I rolled my window down (power windows) all the way and it keeps popping off the track...idk why its doing this and it just started the other day so i took the door panel off and put it back on and it keeps doing this..anyone have a clue why this is happening? thanks in advanced
Old Nov 12, 2007 | 10:18 AM
MattsGreenEG's Avatar
Default Re: Window popping off track? (98ej8coupe)
my car (manual power) does the same thing bump for this
Old Nov 12, 2007 | 10:20 AM
BlueIntegraBoy's Avatar
Make sure the window regulator is bolted straight. When I replaced my window regulator and I didn't bolt it completely straight, then window came off track.
Old Nov 12, 2007 | 10:21 AM
Malakai's Avatar
spray some silicon lube on the rubber track. This works as a fix for a while. Just have to re lube every few months. This is what i do.
U can also buy the part new and this may act as a solution. Sorry cant recall what the part it called off the top of my head.
This is a known problem for 96-00 civics
Old Nov 12, 2007 | 10:27 AM
Default Re: (Malakai)
nvm found it
https://honda-tech.com/zerothread/2061336
Old Nov 12, 2007 | 10:31 AM
98ej8coupe's Avatar
Default Re: (MattsGreenEG)
thanks guys looks like im buying some silicone spray tonight
Delicieuxz
Feb 24, 2018 05:42 AM
central_driver
49
Sep 25, 2012 06:51 PM
TwoKSiR
Nov 4, 2007 02:33 PM
samson1
Jun 21, 2004 08:35 AM
EX-T
Nov 27, 2003 07:26 AM
