Made me a dual gauge bezel and aluminum temp. sensor adapter!
Old Nov 12, 2007 | 09:19 AM
mac_24_seven's Avatar
Default Made me a dual gauge bezel and aluminum temp. sensor adapter!
Gotta get a couple daytime pics. ANd the angle of the pciture makes it look like I can't see alot of my cluster, but really, sitting normal, I can't see the MPH mark and right at 1,000 RPm. If I stretch justa hair, it's all visible.
Also, made this for my temperature sensor. Its my uber cheap version of the more expensive, prettier ones I won't have to ditch my stock temp gauge with this
Nice N Smooth.
The sensor will be at the very very top of the pipe, so there should be little to zero interference of water flow
Old Nov 12, 2007 | 09:43 AM
89civicdx's Avatar
Default Re: Made me a dual gauge bezel and aluminum temp. sensor adapter! (mac_24_seven)
Does that go in the rad hose? are you gonna lay beads on the ends....or the hose might slip off
Old Nov 12, 2007 | 09:58 AM
Default Re: Made me a dual gauge bezel and aluminum temp. sensor adapter! (89civicdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicdx &raquo;</TD></TR><TR><TD CLASS="quote">Does that go in the rad hose? are you gonna lay beads on the ends....or the hose might slip off </TD></TR></TABLE>
Been debating on that actually. I had decided that I would just hose clamp it on there as good as I could and see what happens.
I wouldn't be able to get a fine enough bead for it to seal, nor consistent enough (it would be bumpy, for lack of a better word).
Old Nov 12, 2007 | 11:44 AM
RC000E's Avatar
Just put a tiny couple dabs around the pipe at each 90 degree point. Use a little less heat so it sits up a bit....no big deal.
Old Nov 12, 2007 | 12:41 PM
m R g S r's Avatar
it doesn't seal at the bead you run at the end of the pipe, that is just there so the hose clamp won't pop up and over it. . . .
Old Nov 13, 2007 | 01:49 PM
mEr's Avatar
mEr
looks good
Old Nov 13, 2007 | 02:59 PM
TurboEK9Coupe's Avatar
Default Re: Made me a dual gauge bezel and aluminum temp. sensor adapter! (mEr)
Nice work. But definitely put some type of beading on the end of the pipe. You don't want to find out the hose popped off when your going down the road.
Old Nov 13, 2007 | 03:34 PM
Mikey3000's Avatar
Default Re: Made me a dual gauge bezel and aluminum temp. sensor adapter! (TurboEK9Coupe)
depends how tight the hose is on it right now. if its tight you won't be able to get the hose over the bead. if the hose is a tight fit on the pipe right now, i'd just rough up the surface a bit like knurls.
Old Nov 15, 2007 | 11:40 PM
civic.slow's Avatar
* B A N N E D *
Default Re: Made me a dual gauge bezel and aluminum temp. sensor adapter! (Mikey3000)
i smell a k swap
Old Nov 16, 2007 | 05:36 AM
jdlracing.com's Avatar
Default Re: Made me a dual gauge bezel and aluminum temp. sensor adapter! (civic.slow)
go to a local sheet metal shop and ask the to bead roll the edges for you. Something that small, they would prob do for $5 if not for free. Depends on the person...
Josh,
JDL Racing
Old Nov 16, 2007 | 05:52 AM
tony1's Avatar
Default Re: Made me a dual gauge bezel and aluminum temp. sensor adapter! (jdlracing.com)
Looks like .125" wall material, you're not going to roll a bead on there, but you should definitely weld some beads on there.
Old Nov 16, 2007 | 06:08 AM
gots_a_sol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac_24_seven &raquo;</TD></TR><TR><TD CLASS="quote">
love that spot for gauges.
Modified by gots_a_sol at 2:38 PM 11/18/2007
Old Nov 17, 2007 | 08:39 PM
Default Re: Made me a dual gauge bezel and aluminum temp. sensor adapter! (gots_a_sol)
your right Tony, I didnt look to see how thick it was.
Sorry bro!
Josh
JDL Racing
http://www.jdlracing.com
Thepowderblue
Acura TL, RL & ZDX
Sep 10, 2012 08:52 PM
Pablo Escobar
May 15, 2006 07:49 PM
TypeR15
Feb 24, 2004 12:29 PM
