Lighting HID/Xenon kits, Retrofits and Associated Topics
Depo Foglights FTL. They dont turn on anymore. I need some advice/help.
Old Nov 12, 2007 | 08:57 AM
skateboard_ej8's Avatar
im hench irl
Default Depo Foglights FTL. They dont turn on anymore. I need some advice/help.
I have the yellow square depo foglights on my 96 civic. They worked well in the begining, then all the sudden they kind of started to flicker then eventually they just wouldnt turn on anymore. I can hear the relay click on and off when i push my foglight button. I put my test light to work, so i go to check the power from the fuse box to the power cable and the test light is on but its really dim. I double checked my grounds and they all check out. Has anybody ever had this issue before? I'll try to take pictures of the set up today and will have them up tommorow. Any help would be greatly appreciated. Thanks in advace.
-Esco
Old Nov 12, 2007 | 09:25 AM
bpr0422's Avatar
Default Re: Depo Foglights FTL. They dont turn on anymore. I need some advice/help. (esco562)
could be bad bulbs, ground, or harness..
edit: https://honda-tech.com/zerothread/1812043
Modified by bpr0422 at 1:43 PM 11/12/2007
Old Nov 12, 2007 | 09:29 AM
im hench irl
Default Re: Depo Foglights FTL. They dont turn on anymore. I need some advice/help. (bpr0422)
Im going to triple check the wiring once i get home.
Old Nov 12, 2007 | 10:53 AM
Padawan's Avatar
Darth ModerVader
I'd probably just re-wire them using my own wiring and relay.
Old Nov 12, 2007 | 12:11 PM
im hench irl
Default Re: Depo Foglights FTL. They dont turn on anymore. I need some advice/help. (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">I'd probably just re-wire them using my own wiring and relay. </TD></TR></TABLE>
What is it that makes the depo lights so "crappy"..? Is it the wiring? the lights, the fuses.? Or are they just overall a non quality product?
Old Nov 12, 2007 | 12:22 PM
im hench irl
Padawan, what are your thoughts on HID equiped foglights? I was thinking on putting yellow HID's in my foglights. Would it be too much glare? Or would the foglights already be low enough to not cause glare? Sorry for all the questions. I have seen many of your posts and you have provided many users with the answers they were looking for. Thanks again, and sorry for all the questions.
-Esco
Old Nov 12, 2007 | 12:42 PM
bpr0422's Avatar
The depo or any aftermarket fog light kit, uses wiring that isn't strong enough to withstand the power draw of the lights that you use.
You can make your own wiring harness...using 16-12 ga automotive wiring...
HID fogs are fine.. if aimed properly.
LOL.. my bad.. i posted the wrong link... https://honda-tech.com/zerothread/1812043
Old Nov 12, 2007 | 02:27 PM
im hench irl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 &raquo;</TD></TR><TR><TD CLASS="quote">The depo or any aftermarket fog light kit, uses wiring that isn't strong enough to withstand the power draw of the lights that you use.
LOL.. my bad.. i posted the wrong link... https://honda-tech.com/zerothread/1812043</TD></TR></TABLE>
I see. Im gona try the thicker wiring. Also the relay seems to get really hot, and there is some sort of buildup around where the relay meets the harness.
Old Nov 12, 2007 | 03:34 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by esco562 &raquo;</TD></TR><TR><TD CLASS="quote">Padawan, what are your thoughts on HID equiped foglights?</TD></TR></TABLE>
The results will vary depending upon the HID kit and the fog lamps themselves. The Civic Depo lamps do not have a particularly sharp or well controlled beam, so I'd probably shy away from overpowering them with HID capsules, and would instead consider something like PIAA Plasma Ion Yellow replacement bulbs for them.
papi123
Honda Civic (2001 - 2005)
Aug 19, 2014 09:11 AM
superdat1
Mar 15, 2011 07:29 PM
96 GSR-T
May 7, 2006 09:57 PM
jdmferiodrvr
Jan 4, 2006 12:04 PM
Ideal
Jan 6, 2004 01:43 PM
