Heater blowing but not hot...
89 CRX HF
Bone Stock
A/C Blows COLD....
Heater blows... but its not hot....
I checked the little arm in the engine bay to make sure it was turned towards the fire wall (heat) and it was....
No clue why it's not blowing hot..
Any ideas?
Bone Stock
A/C Blows COLD....
Any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">Change your thermostat. Srsly.</TD></TR></TABLE>
I'm being super serial here guys!
HAha. Ok seriously speaking, make sure your circulating water inside that heatercore. Could have a air bubble in the way, or the valve shut (broken or jammed). Only other reason for it not to work is if your heatercore is completely rotted away and you have no more fins left.
check under the heater core. there are cables going to a white plastic lever arm. its VERY common that this comes off after time. it controls the air mixture flap. so basically its closes the air from the blower from going through the heater core.
im pretty certain this is your issue.
while under the dash and looking up, like behind the stereo, reach up and turn the temperature adjustment ****. youll see the cables move. follow that to the white arm and fix it back in place. should be obvious how.
theorigkav3
Feb 9, 2011 11:49 AM
