94 Accord turns over but won't stay running
Old Nov 12, 2007 | 07:11 AM
Sin-D's Avatar
Default 94 Accord turns over but won't stay running
It started two days ago while going down the road all my guages just died and then turned back on. Then it did it and died, but started back up. But the last time it did it, it wouldn't start. After putting a mulitimeter on the coil plugs and ignitor all were fine I can hear the relay and fuel pump engage and found if I turn the key then back off the starter it will stay running but not all the acc work.. I'm baffeled any Ideas?
Sin-D
Bakersfield, Ca.
Old Nov 12, 2007 | 07:35 AM
Honda-Master's Avatar
Default Re: 94 Accord turns over but won't stay running (Sin-D)
electrical part of the ignition switch,,, replace it..
Old Nov 14, 2007 | 07:59 AM
Sin-D's Avatar
Default Re: 94 Accord turns over but won't stay running (Honda-Master)
That was it! You are the best! Thank-you so much!
Old Nov 14, 2007 | 05:31 PM
INNOVA's Avatar
Let try main fuel pump relay.
pullingin
Oct 28, 2016 02:56 AM
loweredimages
Feb 18, 2014 07:13 AM
deltazlt
Mar 24, 2013 07:20 AM
Lizz.dee
Apr 13, 2012 02:11 PM
WaYtOoLoW
Feb 24, 2010 06:30 PM
