Lighting HID/Xenon kits, Retrofits and Associated Topics
HOW DO I CHANGE THE SPEED OF MY TURN SIGNALS? PEOPLE WHO KNOW PLEASE ANSWER.
Old Nov 12, 2007 | 01:32 AM
818blue818's Avatar
Default HOW DO I CHANGE THE SPEED OF MY TURN SIGNALS? PEOPLE WHO KNOW PLEASE ANSWER.
IF YOU DONT KNOW,
IF YOUR NOT SURE,
IF YOUR GUESSING PLEASE DONT ANSWER AND WASTE MY TIME.
IF YOU KNOW PLEASE ANSWER.
I HAVE AN 88 HONDA CIVIC DX HATCHBACK NO SUNROOF OR MOONROOF.
MY TURN SIGNALS ARE STOCK SPEED BUT WOULD LIKE TO MAKE FOR IT TO BLINK FASTER. THANKS
Modified by 818blue818 at 10:06 AM 11/12/2007
Old Nov 12, 2007 | 01:49 AM
STREETWERKZ's Avatar
Default Re: HOW DO I CHANGE THE SPEED OF MY TURN SIGNALS? PEOPLE WHO KNOW PLEASE ANSWER. (818blue818)
damn.... old school ricer modification. i'll admit, i did it to my car in the mid 90s.
(i also know how to modify an alarm siren to turn it into a wolf whistle hehehe)
one way is to cut a negative or ground wire on the blinker harness, causing a short.
another way you can do it, remove one of the bulbs outright.
good luck with the tickets.
Old Nov 12, 2007 | 01:53 AM
~sp33~'s Avatar
EFB055
Wasnt this only posted recently? Buy one of those blinker things off of egay, they actually list them there.
Found it:
https://honda-tech.com/zero...age=1
Old Nov 12, 2007 | 03:06 AM
A BOOSTED CRX's Avatar
Default Re: (~sp33~)
YEAH IT WAS JUST POSTED, DO YOU HAVE TO USE ALL CAPS FOR US TO BE ABLE TO READ WHAT YOU WROTE?
JUST TAKE A BULB OUT, MAKES THE LOOK COOL WHEN THE BLINK FASTER...........................................W TF
Old Nov 12, 2007 | 03:38 AM
crx_si-r's Avatar
Default Re: (A BOOSTED CRX)
another way to do it is put in a LED turn signal bulb.
Old Nov 12, 2007 | 08:24 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 818blue818 &raquo;</TD></TR><TR><TD CLASS="quote">IF YOU DONT KNOW,
IF YOUR NOT SURE,
IF YOUR GUESSING PLEASE DONT ANSWER AND WASTE MY TIME.</TD></TR></TABLE>
Lose the caps lock, lose your negative attitude, and learn to use the correct "you're" if you plan to participate on this forum.
http://www.hyperblinker.com
Old Nov 12, 2007 | 08:45 AM
devani's Avatar
Default Re: HOW DO I CHANGE THE SPEED OF MY TURN SIGNALS? PEOPLE WHO KNOW PLEASE ANSWER. (Padawan)
There is another way
this is for the 7th gen civics, but the point is flasher is located inside fuse panel for every car...
simple for a skilled person...i dont know about you...
http://www.civicforums.com/for....html
Old Nov 12, 2007 | 11:33 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Yeah you can get adjustable flasher relays from JCWhitney and such.
Have fun making your car look like a blinker is burned out all the time, in other words, looking ghetto.
Old Nov 13, 2007 | 11:19 PM
DA_PoWeR's Avatar
For those of us who have baught a car with the turn signals already fast. how do we get rid of that bs. and make them normal again?
Old Nov 13, 2007 | 11:21 PM
Default Re: HOW DO I CHANGE THE SPEED OF MY TURN SIGNALS? PEOPLE WHO KNOW PLEASE ANSWER. (DA_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">For those of us who have baught a car with the turn signals already fast. how do we get rid of that bs. and make them normal again? </TD></TR></TABLE>
bahhhhhhhhhhhhhhahaa!!!
i guess check all the wiring around your blinkers. make sure they arent spliced into. check to see fi you dont have a dead bulb.
Old Nov 14, 2007 | 03:18 AM
Community Builder
Usually fast blinking is caused by lower resistance through the flasher relay, which usually means a turn signal bulb is burned out.
JDM_CRX_PLEASE
Jul 24, 2007 06:44 PM
GSR_96814
Oct 27, 2005 03:02 PM
jolt-tsp
15
Mar 21, 2003 08:15 AM
SilverDc2
Oct 10, 2002 03:31 PM
EySiKaL
Sep 12, 2001 05:03 PM
