ls vtec/gsr internals or stock gsr???
well i have the choice of a rebuilt ls vtec with gsr internals.... or a b18c1 stock....
the guy i was talkin to said ill have more torque and horsepower out of the ls vtec with gsr internals. and it would be the same horsepower as a b18c1 gsr. he said it also takes boost very well and even better than a gsr cuz i eventually want to boost it...
so what do you think?
i originnaly wanted a b18c1
but now that he told me about the ls vtec with gsr internals..im kind of wanting that instead
any opinions
thanks
any opinions
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsdB16aEj1 »</TD></TR><TR><TD CLASS="quote">ls blocks aren't meant to rev like a gsr block, unless you build it and tune it.</TD></TR></TABLE>
Yep. The LSVtec would be stronger, but since there is no oil squirters it can't the revs like a normal LSVtec could. But if you were to build the bottom end with forged internals - It wouldn't matter anymore.
Whatever your plans may be, if you boost on stock- Get a GSR.
If you play to build the bottom end when you boost- Get the LSVtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CapnKrunch »</TD></TR><TR><TD CLASS="quote">Get the GSR. It will be much more reliable than the LS/VTEC.</TD></TR></TABLE>
Ignorance
LSVtec can be a reliable motor, it just depends if you take shortcuts when you build it or not and just gotta know what you're doing.
Here's a link for you:
https://honda-tech.com/zerothread?id=1676914
Ignorance
LSVtec can be a reliable motor, it just depends if you take shortcuts when you build it or not and just gotta know what you're doing. Here's a link for you:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViSiONxBoY »</TD></TR><TR><TD CLASS="quote">
Ignorance
https://honda-tech.com/zerothread?id=1676914</TD></TR></TABLE>
thanks alot for the information man. helped a lot and that link
yeah i was planning to run low boost around 8psi on stock ...and i wouldnt be the one to rebuild the bottom end so i wouldnt have the money for someone to pull out my engine and do that
so yeah im probably going to go with the gsr.
thanks
Ignorance
thanks
okay so now i have another question.
you say the block of a ls isnt meant for high revs like a gsr. if theres all brand new gsr internals would it matter cuz then itd be just like a gsr block?
if i have an ls vtec with all gsr internals(pistons,rods,etc) wouldnt it be reliable and be able to stand revs like a gsr? and take boost like a gsr?
i heard going ls vtec is just better cuz of the torque and with the gsr internals id be making more hp than a stock gsr.
anyone can help me? im stumped?
i also just read that theres not a stock ecu that will runa ls vtec very well because its not a stock honda motor. well if its got all gsr internals..would a gsr ecu work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jxhxb »</TD></TR><TR><TD CLASS="quote">okay so now i have another question.
anyone can help me? im stumped?</TD></TR></TABLE>
No, aside from the piston/rods running like a stock gsr, in the block.
An LS block doesn't have oil squirters, while an OEM GSR block would.
But if you were to get forged pistons/rods- that wouldn't be much of a problem.
And if you're talking about boost, both motors are great on boost
