distributor.. vtec one matter?
Old Nov 11, 2007 | 06:06 PM
boostedeghatch's Avatar
Default distributor.. vtec one matter?
we just installed a JDM D15b vtec distributor from hmotorsonline in a vx hatchback.
car wouldn't strat and it turned out to be the distributor is bad. i got the coil and ignitor from an obd2 distributor and put them in the obd1 distributor, but that still didn't work.
question: can i use a non vtec obd1 distributor? if i'm correct, i'm guessing it would start the car, not all the whole will line up and it will more than likely be off ignition timing.. is that right?
Old Nov 12, 2007 | 01:05 AM
suicide_shift's Avatar
* B A N N E D *
Default Re: distributor.. vtec one matter? (boostedeghatch)
no the VX is vtec-e you used an obd1 vtec dizzy thats why it wouldnt start....cant use obd2 coils in an obd1 dizzy and expect it to wrok. and the nonvtec dizzy will not start it.......
go find a VTEC-E dizzy and you're done
Old Nov 12, 2007 | 08:19 PM
Default Re: distributor.. vtec one matter? (suicide_shift)
we put a non vtec dizzy in the car and it started it.
i got a z6 distributor and started the car, but it doesn't run right. would the car being a vx with a z6 distributor have anything to do with it? the car still has the vx ecu.
Old Nov 12, 2007 | 09:05 PM
* B A N N E D *
ya the z6 ecu is diffrent than the VX both are vtec but they are diffrent forms..read up on vtec-e.........they are diffrent
Old Nov 12, 2007 | 11:33 PM
i know they are different, but you think it would make the car run shitty if i'm not using a z6 distributor but using a vx ecu?
Modified by boostedeghatch at 8:52 AM 11/13/2007
Old Nov 13, 2007 | 11:26 AM
* B A N N E D *
do whatever you want............but it isnt going to run right until you get the right part.......................................**** if you're having this much trouble and really want to use that z6 dizzy go swap a z6 in it!
look up how vtec-e works........
then you'll see that a
non-vtec dizzy wont work and a vtec dizzy wont work only the vtec-e dizzy will work in a vtec-e equipped VX .........................
the prolems you listed ALL stem from the wrong dizzy being used....swap it back before you start driving it with the advanced igniton timing and expletive your motor up...........you'll be back here blaming me for blowing your motor
why is it so hard for you?????????
use the VX ecu and you're done!!!!!!! its simple you're ******* things up using the wrong dizzys........................................
Old Nov 13, 2007 | 04:16 PM
its the vx ecu thats making it run crappy. we put a p06 ecu in the car today and it ran, no problems. put the vx ecu in and it went back to crappy.
88EDHatch
Dec 3, 2010 10:02 AM
allmotaR
Northwest (Sales)
Feb 14, 2009 01:40 AM
SIsohcvtec
Sep 6, 2004 04:44 AM
Neukin
Feb 1, 2003 06:24 PM
