Removed A/C belt! WOW!
Old Jun 24, 2002 | 01:59 AM
DutchITR1689's Avatar
Default Removed A/C belt! WOW!
I just removed the A/C belt (not completely out of the car) to see what difference it would make. It was definately noticeable. It has the same effect as removing P/S!!!! I turned the A/C pulley by hand and the resistance was almost the same as the the P/S pulley. I didn't expect it to be that heavy!!!
Old Jun 24, 2002 | 09:09 AM
norice's Avatar
Default Re: Removed A/C belt! WOW! (DutchITR1689)
Switching off the AC has pretty much the same effect as removing the belt.
Old Jun 24, 2002 | 09:16 AM
Chris's Avatar
Default Re: Removed A/C belt! WOW! (norice)
Yea... Its in your head man.. there is almost NO parisitic drag on the motor when the AC is off..
You WILL NOT feel a difference.
Old Jun 24, 2002 | 09:28 AM
Type-Rare#1248's Avatar
Default Re: Removed A/C belt! WOW! (Chris)
no way
Old Jun 24, 2002 | 09:34 AM
Back in Black's Avatar
Rather OG
Yep, which is why I took the whole SYSTEM out
Jason-
who likes being "light"
Old Jun 24, 2002 | 09:35 AM
tonyxcom's Avatar
Default Re: Removed A/C belt! WOW! (Type-Rare#1248)
yeah, there is an electronic clutch on the ac pully. When the ac is off the pully is spinning on a bearing and not turning the compressor.
The only drag you will see is from the tension on the belt, which isnt much and the weight of the pully, which isnt much either.
I doubt that you would be able to feel any difference unless your ac pully was malfuntioning.
Old Jun 24, 2002 | 09:50 AM
PM-Performance's Avatar
Default Re: Removed A/C belt! WOW! (tonyxcom)
i took mine all the way out and i feel the diff. that is unneeded wieght. . . btw ac is overrated
Old Jun 24, 2002 | 03:24 PM
mstewar's Avatar
exactly what I was about to say.. i had an a/c pully problem, and had to cut the belt off.. it felt a lot stronger after i cut the belt off, but when I fixed the pully and put the new belt on, there was not a noticeable amount of drag that came back(with the a/c off of course)..
Old Jun 24, 2002 | 03:28 PM
morepoop4u's Avatar
Default Re: Removed A/C belt! WOW! (mstewar)
when i put my ps belt back on it started squeaking, what can that be from.
Old Jun 24, 2002 | 03:41 PM
reefer_bob's Avatar
Default Re: Removed A/C belt! WOW! (morepoop4u)
Depends if its the belt squeeking or the PS pump squeeking. Belt and or pully could be dirty, or the PS Pump could be losing a bearing...
Old Jun 24, 2002 | 03:44 PM
vwong's Avatar
Most likely your belt has too much tension.
single_slam
Feb 23, 2014 05:40 PM
sebTeggy
Nov 7, 2011 01:22 PM
ATrin
Jul 2, 2008 07:49 AM
efyou
Aug 12, 2007 07:40 PM
mattL
Jun 21, 2002 09:00 AM
