mpfi swap problem
Old Nov 11, 2007 | 05:02 PM
blackedout89crx's Avatar
Default mpfi swap problem
i did a mpfi swap on a 89 auto crx with a d16 the car will turn on and run for about 2 seconds and then die and my engine light oil light and battery light are on (battery and oil are fine) any help please
Old Nov 11, 2007 | 05:08 PM
wiZCo's Avatar
Stouts 'n' Scotch
Well, the battery and oil lights are on because the engine died.
Check your ECU for codes, the most common issue with MPFI swaps is incorrectly done wiring.
Old Nov 11, 2007 | 06:36 PM
Default Re: (wiZCo)
i dont kno how to check the codes cause the ecu is different from pm5 to p28 i dont kno which pins to touch the only wiring i did was the injectors a1,a3,a5,a7 dont kno what elso to do
GamerOnHorizon
Dec 24, 2018 12:55 PM
yanirita911
Jun 24, 2018 05:59 PM
ef9alldatime
Sep 28, 2008 06:14 PM
s2kkk
Mar 17, 2004 03:44 PM
dpine
Oct 14, 2003 04:01 AM
