HELP NEEDED AGAIN
I have no clue what the hell is going on with my pile, but I need competent help. Codes #6, 14, 20 and 10. I know what the codes are, and I have gone through 3 IACV's already, and I am about to get roid rage. About to burn my damn car down, that's how pissed I am. (209)570-6535 Josh
Live in Galt, in between Sac and Stockton
#6 is ECT, engine coolant temperature sensor, located on your lower water neck
#14 is IACV, could be bad wiring or plug since you went through 3 IACV's
#10 is IAT sensor, located in the intake for 96-00 civics and on the intake manifold for integras
#20 is electric load detector circuit, check wiring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex »</TD></TR><TR><TD CLASS="quote">#6 is ECT, engine coolant temperature sensor, located on your lower water neck
#20 is electric load detector circuit, check wiring</TD></TR></TABLE>
yep, exactly what he said, but double check the 2 main grounds first for code 20. hondas are well known for not running even not starting w/ a unwired ground. the one on the tranny to the chasis & the one from the valve cover to the radiator support.
TheNasty0ne
14
Apr 19, 2005 10:43 AM
Stoich EG2
Dec 15, 2004 11:27 AM
