Brake Cleaner Valve Test?
Old Nov 11, 2007 | 04:06 PM
huge230's Avatar
Default Brake Cleaner Valve Test?
I am just wondering if you need the spring installed to see if brake cleaner seeps through or not?
Or should the valve just seal by holding it there?
Also if the valves dont seep brake cleaner does it pretty much guarantee they are seated right?
Old Nov 11, 2007 | 05:14 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Brake Cleaner Valve Test? (huge230)
The springs are needed to maintain seat pressure. If it doesn't leak, you should be good.
Old Nov 11, 2007 | 05:53 PM
huge230's Avatar
Default Re: Brake Cleaner Valve Test? (Dogginator)
thanks
nicky352
19
Mar 27, 2023 08:56 PM
afnan
Dec 15, 2013 11:07 PM
vu337
Jan 8, 2007 05:49 PM
