oil coolers
Old Nov 11, 2007 | 02:29 PM
imachikciviclover's Avatar
Default oil coolers
does a d16y8 come with a oil cooler..........cause i have a oil leak i can tell right now if its a gasket or what but it didnt start happing till i had a wreck
Old Nov 11, 2007 | 02:41 PM
Archidictus's Avatar
Unceasing Measure
Default Re: oil coolers (imachikciviclover)
If you're talking about a radiator-style oil cooler, no, it does not. You may be leaking transmission fluid or power steering fluid from the front area of the car. Is it an automatic? What kind of wreck were you involved in?
Old Nov 11, 2007 | 02:49 PM
Padawan's Avatar
Darth ModerVader
Default Re: oil coolers (Archidictus)
Yes, it's possible that you're leaking PS fluid, though that should be easy to determine by the distinctive smell that PS fluid possesses.
Old Nov 11, 2007 | 02:51 PM
i have a manual.[i was driving and some women from the right side of the street at a chic fil la pulled out in front of me and i didnt have time to stop it hit her driver wheel no damage to her car...but mineBody: front bumper driver finder headlight and rad support and the frame is pushed back a little...
Old Nov 11, 2007 | 02:55 PM
Unceasing Measure
Seems like that would be a prime candidate for a power steering leak. Did you just assume it's oil because you don't know any better or are there symptoms suggesting that your oil pressure is low or what? Power steering fluid is generally clearish yellow to dark yellow in color and it smells nothing like engine oil. Can you take a picture for us?
Even so, if you were hit because of another driver's inability to abide the rules of the road, shouldn't you be letting insurance take care of the repairs?
Old Nov 11, 2007 | 02:57 PM
forcefedferio's Avatar
sounds like you got the power steering cooler....does your steering feel rough? if it doesnt now it will start to and the pump will begin to whine if that is what it is.
Old Nov 11, 2007 | 03:11 PM
Default Re: oil coolers (forcefedferio)
ok i jacked the car i started taking off the exaust because im stripping the car.....i already got the check for the wreck i jus dont want the car anymore to many problems...but anyways when i jacked it up on the stands i was looking around...now i know what oil looks and smells like and it wasnt like pouring out it was just maybe a lil bit on the oil pan....so i figured it was oil but i cant see where its coming from.....cause its dark here
EGToFlyy
15
Nov 14, 2013 06:04 PM
faSHOwidIT
14
May 5, 2006 02:16 PM
JCracer723
Mar 25, 2004 09:46 AM
JCracer723
Dec 21, 2003 05:27 PM
